2018 Ecoboost, bolt-on mods. On Saturday, left my home heading to Ohio early. two hours in, these codes popped up, truck not running right. sputtering, no power, high rpm's before shifting. turned truck off, restarted and everything fine, no wrench on display. Sunday morning, same exact thing happened. left home early, heading to Ohio but not quite same area and about two hours in, BAM, same exact codes!!! turned truck off, restarted and immediately wrench gone.
I read DCT codes from nguage. Saturday was raining pretty hard. Sunday, no rain in beginning but started raining about 10-15 minutes prior to incident. could something be getting wet? truck ran fine all the way home and ran good Monday on way to work. The two hours driving time is kinda weird, could something be getting hot?
yes, I have installed Full Race intercooler and removed all of the shutters behind the upper grill. The shutters on the lower where the original cooler was, they are still there.
You will need to use ForScan to disable the shutters so they won't send a code. That's probably tied to the throttle as well and why you're getting that code. Don't ask me what the value are for those, as I don't know. A Google search will probably get you there though.
The P0068, is "Throttle position sensor" as stated by @JKBrad. The U0284 is "Lost Communication with active grill shutters", and there is no such code as a "P068".
