First warm day here in VA and I turned on the AC. Front feels cold, maybe not ice cold but cold. Rear is definitely not refrigerated air. When I turn the rear temp up, it blows hot. But when I turn it to cold, it is just kinda warm. Any ideas before I head to the Ford dealer? 2017 Exped Limited with 58k miles. Out of warranty. Thanks
If the issue was with just the front or rear I would've said a blend door issue, but since the front and rear are both warmer than usual it's most likely the system needs a shot of refrigerant.
If the issue was with just the front or rear I would've said a blend door issue, but since the front and rear are both warmer than usual it's most likely the system need a shot of refrigerant.
