2002 excursion Rear AC not Blowing cold
Old Jul 11, 2007 | 09:49 PM
vreynaud's Avatar
vreynaud
My rear AC on my 2002 excursion is not blowing cold air, the controls on the ceiling work: fan control, panel/floor but the temp does not work.
I checked all the fuses on the inside panels: they are OK, except 1 that was for the secondary cigarette lighter on the front dash.
Is there a second AC unit?
a different fuse?
where should I start looking?
thx in advance
Old Jul 11, 2007 | 10:17 PM
igotoneforya's Avatar
igotoneforya
Posted by Brians97F250CREW (search for air condiontioning quit) ....igotoneforya there is only one compressor that runs both front and rear systems. The rear system operates off an expansion valve in the back which converts the high pressure low temp liquid back to a low pressure gas. These valves get stuck and need to be replaced. If your front is cold and the rear isn't that's probably your culprit. The system has to be evacuated to replace it.
This is the reply I got when I asked the same question...I never got around to it yet. Ford estimated it to be $250 and my AC guy was too busy to squeeze me in yet.
Old Jul 17, 2019 | 05:57 PM
leilani2103's Avatar
leilani2103
2002 FORD EXCURSION REAR AC CONFUSED
I HAVE A 2002 FORD EXCURSION THAT HAS OVER 220000 MILES. THE FRONT AC WORKS FINE EXCEPT WHEN AT A DEAD STOP. WHILE AT A LIGHT OR IN TRAFFIC THE AC DOESNT BLOW COLD COLD. IT BLOWS COOL. BUT THE MINUTE WE TAKE OFF IF BLOWS COLD. MY BIGGEST PROBLEM IS THE REAR AC. DURING NORMAL WARM/HOT WEATHER CONDITONS THE REAR AC WORKS FINE. BUT WHEN IN EXTREMELY HOT WEATHER CONDITIONS, TYPICALLY OVER 100 DEGREES, IT JUST BLOWS WARM/HOT. CAN ANYONE HELP?!?!?!
Swaybar1
Jun 19, 2015 04:34 PM
jeffrey5679
May 8, 2013 09:29 AM
zmanmike
24
Apr 21, 2008 11:18 PM
trucker56
Mar 8, 2008 07:38 PM
chaneyb
Jun 21, 2005 03:42 PM
