Ac Blowing Cold From Rear
To me this sounds like you are running low on refrigerant. The back AC always do a better job than the front because they do not have a blend door. They always run colder than the front (at least with my experience). When ever I had the front perform poorly with the A/C it was because of low refrigerant. It unfortunately also means that you probably have a little leak somewhere.
CONVERT TO R134a
