U Joint Flange Removal
Old Apr 19, 2019 | 08:21 PM
  #91
78ShortBed-'s Avatar
78ShortBed-
Originally Posted by Mearntain
Hopefully I'll get to use my chef boyardee ravioli can this time too to place the axle seal. I tried using it for the pinion seal but it was just barely too small. I wasted a whole can for nothing...
We used to use 2# coffee cans on big trucks.
And sometimes no access to a wheel dolly, so we would grease up a 1x12 and let the wheel down enough to touch the board, then slide it off the spindle.
Those were the days.
Old Apr 20, 2019 | 06:26 AM
  #92
Mearntain's Avatar
Mearntain
You gotta do what you gotta do! Sometimes the backyard ways work out better anyways.
Old Apr 20, 2019 | 07:52 AM
  #93
Crop Duster's Avatar
Crop Duster
While you have those axles out. Spin the bearings if they make more than one revolution or sound rough you might want to replace them while everything is apart. Remember they are permanently lubricated whatever grease was in them when new is all there ever will be.
Old Apr 20, 2019 | 07:55 AM
  #94
Mearntain's Avatar
Mearntain
Good call, I'll double check that when I have them out. I'm pretty sure when I reinstalled them the other week, I did check for that, and I'm pretty sure I remember a half spin and that was all. Or maybe that was the fronts that I remember that being the case on? Either way, I'll double check again this time to be sure, thanks for bringing that up.
Old Apr 20, 2019 | 08:13 AM
  #95
Mearntain's Avatar
Mearntain
Just got out to the garage and noticed something funny. Hopefully I didnt break anything in the process and it's as simple as just tightening the pinion nut more.
I noticed when I turn the the axles, the drive shaft doesnt spin. If I turn the drive shaft, the axles will spin, but touching a stud with your pinky finger will cause the axles to stop spinning.
Please tell me this is as simple as just needing to tighten the pinion nut more??
Old Apr 20, 2019 | 02:42 PM
  #96
Mearntain's Avatar
Mearntain
Completely ignore my last post...both wheels were off the ground and I didnt have a prybar holding one still, no wonder the yolk wasnt spinning.. I feel like an idiot now, I'll excuse myself from here ha
Old Apr 20, 2019 | 05:35 PM
  #97
Tedster9's Avatar
Tedster9
Yolk is the yellow portion of an egg.
Jus sayin'
Old Apr 20, 2019 | 06:06 PM
  #98
Mearntain's Avatar
Mearntain
Jus sayin'
Ha good catch. Autocorrect gets me all the time
Old Apr 21, 2019 | 09:50 AM
  #99
78ShortBed-
I think we all have that occasional brain bead dump.
bbf150
May 22, 2013 08:45 PM
trap4x4
Apr 27, 2011 10:56 AM
AlaskaJeff
Oct 9, 2009 09:14 AM
JimBobWay
Jan 1, 2009 02:42 PM
chrono4
Jun 21, 2006 06:30 PM
