Sponsored by: Real Truck
Transmission questions
Old Mar 31, 2019 | 11:43 AM
big315's Avatar
big315
OK, Gents,
I have a 2007 F-350 Diesel with 215,000 miles. When the temps are cold outside, my transmission bumps like it needs to warm up in the morning. Once it gets warm, it runs like a top. Great mileage and responsiveness and rides like a dream. About 30,000 miles ago, I had the transmission filter changed and all the transmission fluid replaced. All 15 quarts. Does anyone have any suggestions as to what I should do?
Thank you guys?
Old Mar 31, 2019 | 07:02 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What transmission fluid is in it now?
Old Mar 31, 2019 | 07:40 PM
big315's Avatar
big315
I had the filter and fluid changed at 180,000. I switched to Royal Purple. I have had great success with Royal Purple.
Old Apr 1, 2019 | 09:35 AM
Mark Kovalsky
What rating does the Royal Purple have? I looked up on of their ATFs and it has a MERCON V rating, not MERCON SP or MERCON LV, which is what your 5R110W transmission requires.
Old Apr 1, 2019 | 02:02 PM
big315's Avatar
big315
So I need to go back with the Motorcraft?
Old Apr 1, 2019 | 03:08 PM
Mark Kovalsky
You need a fluid with either MERCON SP or MERCON LV ratings. Brand doesn't matter.
Any MERCON V fluid will destroy this transmission. I don't know if Royal Purple makes the right fluid or not. I didn't spend much time researching it. The one that I looked at was MERCON V, they may have others.
If you used a MERCON V fluid in this trans you want to get as much of it out as possible. This is the best way I know of to change the fluid: https://www.ford-trucks.com/forums/1...-exchange.html
Old Apr 1, 2019 | 03:10 PM
Djosbun's Avatar
Djosbun
Never ever ever deviate, no matter what vehicle you drive, from the manufacturer’s recommended transmission fluid.
Follow Mark’s recommendations to the letter, as he is THE KING of Ford transmissions.
— Dave
Old Apr 2, 2019 | 08:16 AM
big315's Avatar
big315
Transmission Questions
I went to the Royal Purple site and here is what it said under Ford with their ATF Fluid.
  • Ford FNR5, MERCON®, MERCON® V
Old Apr 2, 2019 | 05:14 PM
Mark Kovalsky
That fluid is deadly to your transmission. You MUST use MERCON SP or MERCON LV.
Old Apr 2, 2019 | 08:11 PM
big315's Avatar
big315
I understand. Thank you for your help!
Old Apr 21, 2019 | 08:43 PM
big315's Avatar
big315
OK. Changed both filters and went back to the Ford Fluid. Still a little bumping on acceleration until it gets warmed up. Is there an additive I can add or something to help with the seals? Just hoping for some advise!
Old Apr 22, 2019 | 07:50 AM
Mark Kovalsky
I have to ask this. What Ford fluid did you use?
Still a little bumping on acceleration until it gets warmed up. .
Give the adaptive software some miles to smooth out the shifts.
What's wrong with the seals now?
Old Apr 22, 2019 | 08:56 AM
big315's Avatar
big315
He put the recommended fluids in.
OK. I'll give it some time.
The only thing I know might be wrong with the seals is that they are old. 13 years and have 216,000 miles on them.
Old Apr 22, 2019 | 09:17 AM
Mark Kovalsky
There are no additives that I'm aware of that will actually help.
Old Apr 22, 2019 | 02:46 PM
big315's Avatar
big315
Thank you Mr. Kovalsky! I appreciate your help. I'll keep you posted.
beerformeplz
May 21, 2007 08:36 AM
mabrant61
Apr 24, 2007 04:02 PM
B1GKAHUNA
Jan 22, 2007 01:22 AM
raptor05
Oct 24, 2006 06:12 PM
BLK94F150
Oil & Lubrication
Feb 21, 2006 05:43 PM
