Mercon V ???
Old May 19, 2007 | 06:13 PM
beerformeplz's Avatar
beerformeplz
Mercon V ???
Just used it for a fluid change ( I only drained the pan and replaced the filter) and the I saw the book says to only use Mercon. Is there going to be a problem? I have 90K miles and really dont want to take a chance on a tranny flush.
Old May 20, 2007 | 02:27 AM
Monsta's Avatar
Monsta
Sit. Stay.
No...the specs from Ford changed last year. Mercon V is NOW the specified transmission fluid for the 4R100. You're safe.
Old May 20, 2007 | 08:32 AM
XylemXorro's Avatar
XylemXorro
What's wrong with a tranny flush?
Old May 20, 2007 | 01:07 PM
jackrista's Avatar
jackrista
with a flush they push all the old fluid through the filter and put new fluid in but dont change the dirty clogged filter.
Old May 20, 2007 | 02:05 PM
Monsta's Avatar
Monsta
Sit. Stay.
Fords never states anywhere that the filter EVER needs to be changed as part of normal maintenance. That leads me to believe that there just ain't a whole lot of stuff that can get in the tranny to ever make a dirty, clogged filter.
I mean, c'mon, the tranny is completely sealed. I've been told that if you ever really need change the filter then the entire tranny is toast anyway.
Flushing is fine so long as it isn't back flushing. With normal flushing the fluid goes through the normal path of operation....nothing out of the ordinary.
Old May 21, 2007 | 08:36 AM
Brians97F250Crew's Avatar
Brians97F250Crew
Monsta .. it's not really what gets into the tranny more so the internals wearing ( clutches, bands, ect... ) that produce the particles that get caught in the filters. Also dropping the pan for a peek also will give you a heads up on the condition of your internals where as just flushing it doesn't.
Flushing is fine in my opinion between a full service but it is important to change the filters also. Don't forget the one on the frame up by the radiator the little toilet paper looknig one.
Skip1970
Jan 24, 2017 02:57 AM
derek0525
Aug 12, 2016 10:45 AM
diyster
Escape & Escape Hybrid
Jun 1, 2016 09:54 PM
comsupany
22
May 31, 2016 10:52 AM
Bananarama
Jun 27, 2011 03:27 PM
