1989 f350 water loss behind motor
Without a picture, it would be hard to help out. Places where the coolant could be near the rear of the engine:
- heater core (but that usually coincides with a sweet smell in the cab and layer of vaporized coolant on the underside of the windshield),
- head gasket,
- warped head,
- coolant plug,
- oil cooler rear header,
- loose or cracked heater hose
Received 3,110 Likes
on
Before going too far and not having a clue, get some radiator dye and a UV/blacklight flashlight. Pour the dye in the radiator, drive it a bit to circulate, and leaks will glow bright green under the UV light.
Also, I've had a couple of IDIs like to weep at the rear corners of the head gaskets when they got overheated one time too many. If so, it means the head gaskets are due for replacement soon.
You could also rent a coolant/radiator pressure tester from a local auto parts store and add some pressure to the rad and try to find it with the engine off and cold
I know I've read about folks retorquing head gaskets. I guess the IDIs like to weep at the back of the head gaskets.
Use a clean piece of cardboard under the truck when you return home from a drive. Remove it the next morning and I bet you will have oil/coolant drips at the back of the head. I did this with my 6.9l IDI in my 86 f250 and it just confirmed that the head gaskets are loose. I still drive it around town though. I just add oil and coolant from time to time. Eventually I need to add head studs since I have a turbo to put on it.
leardvr
04-17-2015 10:16 PM
86302f150
02-03-2009 02:16 PM
crawdad
04-01-2006 04:27 PM
