I’m actually surprised Ford has not trickled more info out since the first news bomb. IMO, they normally play the media really well to maintain interest.
They probably feel like the don't need to generate anymore interest. :P
Maybe, but only in terms of how **** poor the 6.6 will compare to the 7.3. Simple math tells us the 7.3 will crush the 6.6
Maybe, but simple math is rarely the whole story. That Chevy has direct injection, and the Ford engineer on the 7.3L kept going on and on about how the 7.3L runs stoichiometric all the time. Still, I expect the 7.3L to best the 6.6L at least by 10% or better. There are reports that Chevy has another gasoline V-8 coming that is over 8L too, but I expect that will be for large commercial trucks only.
**** poor is a bit harsh considering the new GM 6.6 is one of the most powerful gasoline pickup truck engines ever offered and seems on paper superior to both the Ford 6.2 and the Fiat 6.4. Ford aimed a bit higher and will likely come in about 7- 10% more powerful.
It all adds up to great news for truck buyers of any brand. The products keep getting better.
HP or TQ per liter would be the way to compare. From my earlier post:
I know nothing of the differences and similarities between the 7.3 vs. the GM LS motors. But if you figure they can't be too far apart, simply apply the HP/Liter:
L96 comes out at 60 HP/L and 63.3 Torque. Applied to the 7.3 you get 438/462,
LS3 comes out at 69.2/68.5. Apply to the 7.3 for 505/500.
So mid 4s for HP, low 5s for torque. .
The new 6.6 comes out to 60.6 HP/L and 68.18 TQ/L. As a 7.3 you get 442/498.
If you watch and listen carefully to the TFL interview of the 7.3L engineer, that guy states that they had a specific output for the 7.3L in mind. Their plan to run the engine at stoichiometric air/fuel ratio at all times for maximum efficiency dictated the 7.3L displacement. Interesting approach.
Is it really? Modern fuel injected engines have been running at stoichiometric ratio the overwhelming majority of the time for decades now. Most calibrations only rich in the mixture at or close to WOT.
I would have imagined engine displacements for the last 50 years have been designed like that.
The same thought crossed my mind, Tom. They really did talk up the stoichiometric ratio though. Seemed to almost insinuate it hasn't been being done all these years? Or maybe I'm just misunderstanding but yeah, same thought.
Of course, but the engineer kept harping that it ran 14:7 to 1 'at all times', like it was some new feature. Maybe he thought the interviewer was clueless and he was trying to point out the obvious?
The whole “designed for stoichiometric ratio” stuff has me confused/curious too. I’m not an engine guy, but it sure seems like this is what all gas engines have to do so they not running lean or rich. Wikipedia isn’t much help either.
Maybe Ford’s engineers conceived the design by thinking about it differently. Just speculating here, but instead of saying they want “x power from a 7.3ltr block” and then designing the injectors and intake, they said “what size engine would be perfect for these injectors and intake?”
Or maybe the engineers found the current gas motors were having to work too hard (rich) in their average environment, so they designed the motor to be most efficient in that region. That would suggest this new motor could be less efficient at certain RPMs than the current platforms, but maybe that doesn’t matter.
Man, this just makes me even more curious about the motor...
This thought was my conclusion. The 6.2 has horrible MPG for the tasks it is asked to do, hence constantly running rich to keep up. Bigger engine and engineered fuel system etc to keep the engine at or near 14.7 nearly all the time would increase MPG while maintaining power.
Initial orders go in August, and we're 2 weeks away from May, so we'll have 3 months to wait for more news... sheesh
