WELDING
Old Mar 27, 2019 | 11:31 AM
peenhead's Avatar
peenhead
WELDING
Going to be installing custom bumpers front and rear on my '02 Ex and plan on welding the mounts to the frame for added strength. Other than disconnecting the battery any other steps I should take to insure I don't cause any harm to the electronics? Thanks
Old Mar 27, 2019 | 04:37 PM
pirate4x4_camo's Avatar
pirate4x4_camo
Battery disconnect should do it.
that said, the way the bumpers bolt on I don’t see how welding them is going to gain you any usable strength.
I have pulled hard enough to stall my 16,000 winch many times and there are no signs of needing any additional strength to the mounts, The bolts themselfs are grade 8 which have a tensile strength of 150,000 pounds per square inch and there’s 8 of them at 1/2” Bottom line, not likely the rest of the truck would survive any impact that would fail the bumper mount bolts.
Old Mar 27, 2019 | 06:31 PM
DavenTn's Avatar
DavenTn
As a rule, attach your ground clamp near or as close as practical to the burn, on a very clean surface. Lift both + and - cables, so there's no possibility of circulating current. All our vehicles had designated grounding stirrups front and rear.
pat420swed
Oct 26, 2015 09:48 PM
jb50F1
Jun 21, 2014 08:38 PM
fireman-81-f150
Jan 14, 2010 06:06 AM
MagKarl
Nov 15, 2009 12:19 AM
Jimbo302
Offroad & 4x4
Feb 25, 2004 08:17 PM
