Bumper Mount question
Old Jun 20, 2014 | 04:49 PM
jb50F1's Avatar
jb50F1
I have a '96 F150, Std cab 4X4. Are the bumper mounts attached to the frame supposed to be at a 90 degree angle from the frame? Mine are at a slightly tighter angle and are causing real problems with installation of crash bars.
Someone may have hit something in the past but I wanted to check before pulling the bumper all the way off and persuading the mounts to a 90 degree angle.
Thanks
Old Jun 20, 2014 | 05:27 PM
Diesel_Brad's Avatar
Diesel_Brad
Yes, 90*
Rewelded back on from old RSK
Old Jun 20, 2014 | 06:36 PM
jb50F1's Avatar
jb50F1
Thanks, my welds look good, the plates are just bent. I hope that a vice grips and a pipe will pull them back to straight once I get the bumper off. Any other recommendations short of a sledge hammer (no room to swing it)?
Old Jun 20, 2014 | 09:11 PM
Diesel_Brad
I Highly doubt vise grips are going to do anything.
I would bolt 2 eye bolts in put a bolt between the 2 eye bolts then use a come a long from the bolt to a tree or something solid to pull on
Old Jun 20, 2014 | 09:29 PM
F350 1990's Avatar
F350 1990
Cutoff wheel, then fresh 3/8th plate SMAW'd
Hydraulic ram w/some heat
I'd go air-compressor driven plasma followed by new plate with a stiffener (since I'm a Miller Elec fan)
Old Jun 21, 2014 | 05:56 AM
Diesel_Brad
It is going to be FAR easier to straighten what you have then cut the old off and weld new on. It is unbelievable how well Ford welded those dam things on
Old Jun 21, 2014 | 07:41 PM
jb50F1's Avatar
jb50F1
Diesel Brad was right. However, a crow bar, a tow strap, a maple tree, and slipping the clutch in reverse = 90 degrees.
I was even able to do it one side at a time with the bumper on. Amazing how well the corners of the bumper now align with the body.
The hardware that came from Go Rhino is a different story. I'm going to have to cut new supports - I should have known when the kit was advertised as fitting all F150s and Broncos from 87-96.
Old Jun 21, 2014 | 08:38 PM
Diesel_Brad
yeah, not even close. 87-91 is completely different than 92-97
1985 Bronco
Aug 21, 2017 06:50 AM
keiths78f150
Sep 9, 2012 11:59 PM
BroncDS
1978 - 1996 Big Bronco
Feb 26, 2011 03:31 PM
PhilBell
Nov 26, 2008 05:51 PM
Jimbo302
Offroad & 4x4
Feb 25, 2004 08:17 PM
