Fog lights + high beams?
Old Mar 21, 2019 | 08:56 PM
UtahGuy's Avatar
UtahGuy
'03 Excursion. I replaced the factory fogs with LED pods, tied into the factory wiring to the fog light switch. I thought I was going to do the "bambi mod" to be able to run the LEDs and high beams at the same time, but apparently Ford moved all the relays to some sort of sealed module that isn't easily hackable.
So now I'm looking for a solution. I can always wire the LEDs to their own switch, but I like a factory-looking dash and wanted to use the fog light switch. Is there any way to bypass this "safety feature"?
Old Mar 22, 2019 | 12:01 AM
SmackDaddy's Avatar
SmackDaddy
I think there’s a thread up top in the Tech Folder.
Old Mar 22, 2019 | 09:03 AM
hbabler's Avatar
hbabler
What LED pods did you install?
Old Mar 22, 2019 | 11:25 AM
UtahGuy's Avatar
UtahGuy
I looked and didn't see one. Can you point me towards it?
Rigid Duallys.
Old Mar 22, 2019 | 11:37 AM
hbabler's Avatar
hbabler
Thanks I have been trying to decide what to go with
Old Mar 22, 2019 | 11:44 AM
UtahGuy's Avatar
UtahGuy
I had them kicking around so I just threw them on. If you're looking for good results from a simple set of pods, I'd go for something with better optics.
Old Mar 22, 2019 | 01:47 PM
exbxtoy's Avatar
exbxtoy
I just installed a kit sold by RiffRaff called The Brite Box, which allows you to have the high beams come on at the same time as the fogs. I also have LED fog lights in the place of the factory fogs, and with the Brite Box I can use the factory fog light switch to turn on all the lights all at once. I did the upgrade to the 05-07 lights at the same time, which I am very pleased with the extra light!
Just make sure you select "with factory fog lights" option
https://www.riffraffdiesel.com/the-brite-box/
Old Mar 22, 2019 | 08:05 PM
UtahGuy's Avatar
UtahGuy
I'll check that out, thanks!
Old Mar 26, 2019 | 04:51 PM
lonnyallison's Avatar
lonnyallison
The fog light on anytime mod is in the Superduty tech folders. I did it a couple months ago using the write up located there.
Here's the link
S&S Diversified
Old Mar 27, 2019 | 02:59 AM
UtahGuy's Avatar
UtahGuy
Here's the link
S&S Diversified
Exactly the info I was looking for, many thanks!
jwhopson
Dec 7, 2014 01:51 AM
Larry NCKS
2004 - 2008 F150
Jan 30, 2010 09:36 AM
jhopkinson
Jul 7, 2003 02:13 PM
Jokenring
May 21, 2003 08:06 PM
daimon1054
Aug 21, 2002 09:22 PM
