Clean out fuel rails before intalling new injectors | Injector inspection and rebuild
Hello, I have a 99.5 F350 and the injector seals are shot.
When I first got it I changed the fuel filter and there was quite a bit of sludge and mud in the bowl.
I cleaned it out but underneath the "stand pipe" there was evidence the dirt made it past the filter.
I cleaned it out and put a new filter and got the truck going but I lost a gallon of oil the other day into the fuel tank just iding it.
The truck has no power and a bad miss.
I plan on doing the icp and valve cover gaskets and looms next payday.
I did drop the tank and rebuilt the sending unit for the gauge and cleaned the 2 filters in the pick up, scrubbed the tank clean with soap and water and dried it out.
I'm going to rebuild the injectors but I'm worried about debris getting into them after I rebuild them.
Is there a method of cleaning the fuel passages in the engine?
thanks!
I have this kit coming the next few days.
Images of the truck.
thanks!
thanks!
I'm really on a budget and I refuse to own a cellphone, never have since 1998
And then inspect the passages after cleaning them with one of these:
Ultra Slim 0.21 inch Dia. Probe USB Endoscope with Semi Rigid Cable USB Type C Adapter Borescope Waterproof Inspection Camera Snake Camera for PC Notebook and Android Device(5M/16.4ft Cable) https://www.amazon.com/dp/B01IGPDMK0..._isOKCbW64HJDQ
You came to the right place. Got a gun cleaning kit?
https://youtu.be/l5bpNNBbNzs?list=PL141EA1E3D88121E9
Way cheaper than official o-ring kits.
I think I'll grab these:
I've never done it so I can't give a good 'how to' on it. Maybe just compressed air would do the trick. If you put anything in there to scrub with it's likely to leave loose particles behind that'll need to be removed. I would just leave them be unless they really needed to be scrubbed out.
The tank had 80 liters of fuel (and oil) in it and thankfully its a plastic or composite type tank.
I already drained it, scrubbed it inside and out with dish soap and water, rinsed and dried it completely.
I then rebuilt the sending unit for the fuel gauge and cleaned the filters in the pick up and flushed all that out.
I gave the fuel away as I have no idea if it was tampered with or had water in it or what.
I just didn't want to risk putting it back in the tank.
You just never know if someone put bleach in the tank or what, too risky.
First thing I did was buy a locking cap.
I tried to replace the slip tank filter but it ended up breaking it right off the mount.
The devil salt brine has killed it.
