Steering U Joint
Old Mar 17, 2019 | 01:39 PM
F-250 restorer's Avatar
F-250 restorer
Steering U Joint
I had to weld up my frame at the steering box and add a plate on either side. The steering box moved 1/2" to passenger side. Rag joint is out of the question due to misalignment. I tried https://www.summitracing.com/parts/brg-013434, but need a double joint. However, the double is too long to fit in the space. That means either shortening the column or buying a new one.
Does anyone have experience with this? This is the double that I was looking at: https://www.summitracing.com/parts/brg-023434/overview/ Is there a reason I couldn't add on to the column mounting bracket, where it mounts to dash, allowing it to adjust further up from the floor?
Old Mar 17, 2019 | 03:24 PM
mark a.'s Avatar
mark a.
What are you working on ?
Old Mar 17, 2019 | 05:30 PM
F-250 restorer
1975 F250. I'm buttoning up after an engine change, change from auto c6 to zf5 manual.
Old Mar 17, 2019 | 08:25 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
I am sure that Flaming River...can get you what you need.
Flaming River - Classic Auto Parts - Vintage Automobile Steering Components - Steering Accessories - Electrical Components
Steering Universal Joints
Old Mar 19, 2019 | 10:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by F-250 restorer
1975 F250
2WD or 4WD?
anaphe
Jul 11, 2022 07:26 AM
RustyTrustyF150
Apr 4, 2014 08:14 PM
78150custom
Sep 9, 2009 12:04 PM
The67Beast
16
Mar 27, 2007 07:35 PM
Comegetsome
27
Jan 14, 2005 10:46 AM
