Ok, So I have power steering on my truck now, but I have a few questions. I have heard so much different stuff about what you need to put power steering on our trucks. Some people say you need different steering column, some people say you need a rag joint, etc. I am wondering if I am going to run into any trouble with my set up. I have the original manual steering column. No shifter on this one. My tranny is 4 on the floor. I then have a Borgeson Steering shaft connecting the column to the input shaft of the P/S gear. I do not have a rag joint.
Do I need a different column, really?
Do I need a Rag Joint? What is the purpose of a rag joint anyway??
By the way, my rig is 4X4 so the gear box is out toward the front of the truck.
If you have the Bendix box that has 4 bolts for top cover with a cast in letter "B" it will be a direct swap with your manual box. With your set up without the original rag joint I haven't a clue, the rag not only corrects alignment but eliminates road noise and vibration. Get a replacement (correct) shaft and rag joint.
If the box has a 2 bolt cover it's a Saginaw box a way better unit, cheaper to rebuild without the leak problems and twitchy steering Bendix gives you but then you'll need the shorter column app 2-2 1/4" shorter with that box.
Oops, I just reread that your trucks a 4 x 4, above reply was for 2 x 4.
Not a clue with 4 x 4's, other members should chime in shortly.
1967 F100 4X4's have a steering shaft and coupling. Since the OP has the original steering column, I assume it's still there. There's no rag joint per se on a 4X4 of this vintage.
Oddly enough, I just finished converting my 1971 4x4 F100 to power steering today. I used the original steering column. I got a steering shaft from Borgeson as well. I also did one of my highboys and I used the original steering column there also.
Sounds like I will be OK with my set up. The conversion was quite easy. I used a P/S gear off of a 73 - 76 F-100/150 4X4 and had the rotation of the shaft reversed. It was practically a bolt up application. Alot easier than I thought.
As I said, it was practically a direct bolt up. I did have to grind a very small area where the front cross member pokes thru. And I had to drill two new holes in the frame and tap one of them. After that it was just bolt up and go, after connecting the P/S lines and such.
Frame horn: A term for the front section of a frame member ahead of the crossmember which terminates in the front bumper. (My definition...perhaps not an exact one, but hopefully close enough!)
Since the steering box in a 4X4 bolts to that section of the frame ahead of the crossmember, I was wondering if you had to do any frame trimming or welding in that area to gain clearance for the box. Apparently not...
When I did my swap, I used all 78-79 F150 components. Not quite bolt on, but after two days I am very happy with it. I did read the article in the tech section but I decided to go the 1979 direction instead. I did find that the 1979 tie rod ends are bigger so I had to get a tapered reamer to enlarge the holes for the tie rods.
I reread your original post and to finish up there, I think the rag joint was most likely the cheapest way to get that job done.
I did the same swap and used the stock steering column without problems. Still haven't found the perfect solution for my drag link though. I used the original one by heating it in the center and turning one end 90 degrees. A little too long though as it turns farther in one direction than the other, but I figured I'd live with it until I can find an adjustable replacement.
Where's the tech section? I'm attempting to convert my manual steering on my 73' f100 4X4 and I'm wondering if I'm gonna need a different steering shaft.
