Reprogram?
Old Jun 9, 2001 | 05:48 AM
Rock_me's Avatar
Rock_me
Reprogram?
Hello Ford owner's
Can a '96 E4OD in my F-150 be
reprogramed for firmer 1-3
shift's? (line pressure) also what can be done about changing the engagement of the overdrive from 40 mph to 55 mph without having to push OD button?
Thank's for your reply
Rock...
Old Jun 11, 2001 | 07:03 AM
TallPaul's Avatar
TallPaul
Reprogram?
Banks makes a module that installs in one hour--the TransCommand. Check it out at Bankspower.com. It firms up all shifts by raising line pressure. I put it in my 460 v8 motorhome (1990) and it works great. Pricey at about $250. May want to check out B&M makes one or more shift kits for this tranny and they cost a whole lot less, which I didn't buy as they didn't have them for my older unit. I think your 1994 may apply though.
Old Jun 11, 2001 | 07:05 AM
TallPaul's Avatar
TallPaul
Reprogram?
Oops. Your 1996 unit. I also would like to know how to hold off OD until 55 mph. My mechanic told me to lock it out in town as it would get poorer fuel milage and is harder on the tranny to run OD at slower speeds. Finally, why is it this tranny won't kick down a gear until you actually stomp the pedal to the floor?
Old Jun 11, 2001 | 07:07 AM
TallPaul's Avatar
TallPaul
Reprogram?
Suprise. I thought I was saying 00ps and found out how to get a dancing frog! That's what I get for not using preview. Now I am going to shut up before I get the record for most posts in a row, each one correcting the last!
Old Jun 11, 2001 | 09:56 AM
xaviar's Avatar
xaviar
Reprogram?
TallPaul is right, Banks makes a unit called the "TransCommand" I have one on my 96 and it works great.
B&M also makes one for 40 bucks that Summit sells. I have one of those on the shelf I never installed because I bought the Power Pack Unit and the Trans Command together. The TC increase's Pump pressure by 20%.
I couldn't tell you how well the B&M works though. You might check around and see if you can find someone with a B&M that you can talk too.
If you decide on using the B&M because of price. Send me an email. I'd send you the B&M for free. It's just sitting on the shelf collecting dust.
Xaviar
Old Jun 12, 2001 | 05:49 AM
Rock_me's Avatar
Rock_me
Reprogram?
thanks guys,, I will check into both of your ideas about the
E4OD shifts,thxs again!
Old Jun 12, 2001 | 05:54 AM
87f250's Avatar
87f250
Reprogram?
[font size="1" color="#FF0000"]LAST EDITED ON 12-Jun-01 AT 06:56 AM (EST)[/font][p].
Old Jun 12, 2001 | 01:52 PM
winfordr's Avatar
winfordr
Reprogram?
KJLYPW
Feb 10, 2007 08:17 PM
redbull660
Modular V10 (6.8l)
22
Aug 18, 2004 06:25 PM
dvhouse
Apr 5, 2004 06:26 PM
bigslurrp
Computer Chips & Tuners
Apr 1, 2004 12:34 AM
bigcmv
Feb 2, 2001 02:34 PM
