E4OD programming
Old Apr 1, 2004 | 10:23 PM
dvhouse's Avatar
dvhouse
E4OD programming
I have a 96 F 350 7.5 with an E4OD. Just had the trans rebuilt and upgraded. Just wondering if I need to have it reprogrammed after installation or if I can just run it and it will do it it on it's own?
Old Apr 2, 2004 | 06:03 AM
Casey's Avatar
Casey
No, it won't reprogram itself, and no, you don't need to do it, either. There is nothing to reprogram, just install the transmission and drive.
Old Apr 5, 2004 | 06:26 PM
kekoaboy's Avatar
kekoaboy
You may get a check engine light after your first drive, this is normal and after 15-30 starts it should go off. The ECU and trans have to get to know each other all over again. Took me a few trips to the shop to learn this.
jerrytown2001
16
Dec 27, 2019 05:24 PM
10strokin
21
Oct 27, 2015 11:18 AM
Gen 1 driver
1978 - 1996 Big Bronco
Oct 24, 2015 08:52 AM
therigwelder
Apr 3, 2014 08:29 AM
ExcellentRed
Feb 7, 2004 11:25 PM
