ID a tranny
Old Mar 15, 2019 | 07:18 PM
1960fordf350's Avatar
1960fordf350
ID a tranny
I'm trying to ID an automatic transmission. Aluminum bellhousing. My friend thought it was a C4. I don't know what it is. It has a square pan with fill tube attached to the pan.
Old Mar 15, 2019 | 10:24 PM
85e150's Avatar
85e150
Probably a Ford o Matic. Some id info here:
Fordomatic transmission
PCCA seems to be a small case FordoMatic:
http://www.charlietranny.com/Fordoma...des_Page_2.jpg
Old Mar 16, 2019 | 10:20 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
It's probably a 3 speed Ford-O-Matic from a car.
TRANS code PCC-A not listed in the truck parts catalogs.
C4 has 11 trans pan bolt holes, introduced initially in 1964 Galaxie 289/Fairlane 260/289, 1965 F100/250 240/300. Was never installed behind Y blocks.
Ford-O-Matic 3 speed has 14 trans pan bolt holes: 1953/56 F100/350; 1957/58 F250/350; 1957/60 F100, 1961 F100 with 223 I-6 only // Misc 1951/63 Passenger Cars.
Old Mar 17, 2019 | 01:10 AM
85e150's Avatar
85e150
The second link above shows Ford-Mercury. They list the trucks also, so it was a car trans if I'm reading that link correctly, and if that link is in fact correct.
Old Mar 18, 2019 | 07:13 PM
1960fordf350
It's an FX 3 speed. Fordomatic is a more general used name. They had a FX and then a MX. Both evolved into the FMX. This is what I read on the link. This particular unit is the small case unit. It is a 61 listed for Ford and Mercury cars.
Old Mar 19, 2019 | 03:43 PM
NumberDummy
Ford-O-Matic is not a Cruise-O-Matic!
FX is the small Cruise-O-Matic, it is not a Ford-O-Matic!
FMX introduced in 1969, was initially installed in Ford/Merc Passenger Cars with 351W's also introduced in 1969. FX & MX did not evolve into the FMX
FX & MX Cruise-O-Matic's introduced in 1958, the MX (aka BIG Cruise-O) wasn't installed in trucks until 1965.
MX was used 1965/67 F100/350 352 & 1965/72 F350 300 I-6. FMX = 1973/77 F350 300 I-6.
PCC-A = FORD-O-MATIC = 1961 Ford/Mercury Passenger Cars 292.
Old Mar 20, 2019 | 07:33 PM
1960fordf350
That's where it all gets mixed up! Yes this tranny is the small case. The rest I wrote was on a chart on a website. It also included that mis-statement about the FMX. Never thought it would fit in my F350.
Old Mar 20, 2019 | 08:47 PM
matthewq4b's Avatar
matthewq4b
Not quite true. The FMX used the more robust MX type internals in the smaller FX type case. The MX and FX were merged to make the FMX. Hence the FMX designation. So it is not incorrect to say they evolved in to the FMX as the FMX evolved directly from the MX/FX. Just as the XT Lod / AOD evolved from the FMX.
littlehillsfarm
Jul 30, 2015 08:53 AM
Thomas Fore
Jul 16, 2012 12:52 PM
Tattyjoe
Apr 2, 2012 11:35 AM
croosteringa
13
Mar 30, 2011 02:20 AM
Mirage
Aug 16, 2009 12:39 AM
