ID a tranny
I'm trying to ID an automatic transmission. Aluminum bellhousing. My friend thought it was a C4. I don't know what it is. It has a square pan with fill tube attached to the pan.
https://cimg5.ibsrv.net/gimg/www.for...b57c9772db.jpg |
Probably a Ford o Matic. Some id info here:
Fordomatic transmission PCCA seems to be a small case FordoMatic: http://www.charlietranny.com/Fordoma...des_Page_2.jpg |
It's probably a 3 speed Ford-O-Matic from a car.
TRANS code PCC-A not listed in the truck parts catalogs. C4 has 11 trans pan bolt holes, introduced initially in 1964 Galaxie 289/Fairlane 260/289, 1965 F100/250 240/300. Was never installed behind Y blocks. Ford-O-Matic 3 speed has 14 trans pan bolt holes: 1953/56 F100/350; 1957/58 F250/350; 1957/60 F100, 1961 F100 with 223 I-6 only // Misc 1951/63 Passenger Cars. |
The second link above shows Ford-Mercury. They list the trucks also, so it was a car trans if I'm reading that link correctly, and if that link is in fact correct.
It's an FX 3 speed. Fordomatic is a more general used name. They had a FX and then a MX. Both evolved into the FMX. This is what I read on the link. This particular unit is the small case unit. It is a 61 listed for Ford and Mercury cars.
Originally Posted by 1960fordf350
(Post 18547510)
It's an FX :-huh 3 speed. Fordomatic is a more general used name. :-huh
Ford-O-Matic is not a Cruise-O-Matic! They had a FX and then a MX. Both evolved into the FMX. :-huh This is what I read on the link. This particular unit is the small case unit. It is a 61 listed for Ford and Mercury cars. FMX introduced in 1969, was initially installed in Ford/Merc Passenger Cars with 351W's also introduced in 1969. FX & MX did not evolve into the FMX FX & MX Cruise-O-Matic's introduced in 1958, the MX (aka BIG Cruise-O) wasn't installed in trucks until 1965. MX was used 1965/67 F100/350 352 & 1965/72 F350 300 I-6. FMX = 1973/77 F350 300 I-6. PCC-A = FORD-O-MATIC = 1961 Ford/Mercury Passenger Cars 292. |
That's where it all gets mixed up! Yes this tranny is the small case. The rest I wrote was on a chart on a website. It also included that mis-statement about the FMX. Never thought it would fit in my F350.
(Post 18549323)
FMX introduced in 1969, was initially installed in Ford/Merc Passenger Cars with 351W's also introduced in 1969. FX & MX did not evolve into the FMX . |
