transmission identification
Old Jul 16, 2010 | 09:02 PM
croosteringa's Avatar
croosteringa
i have a 66 f-100 trying to find what transmission its has. its a reman tag has part number c6tp 7000 pdba and serial# 16157 jh4h6. can anybody help
Old Jul 18, 2010 | 02:36 AM
Boss9F100's Avatar
Boss9F100
PDB-A is a 65-66 Cruise O Matic. Thats if the tag is on right trans. Pic or how many pan bolts? Most likely the C/M trans. Is the bell housing removable?
Does it look like this? If so its a C/M
Old Jul 18, 2010 | 01:32 PM
Customcab's Avatar
Customcab
Cruise-omatic 14 or 15 bolt pan
C-4 11 bolt pan
C-6 17 bolt pan
Is the only shade tree mechanic way I can tell!
Old Jul 18, 2010 | 02:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by Customcab
Cruise-o-matic 14 or 15 bolt pan
C-4 11 bolt pan
C-6 17 bolt pan
Ford-O-Matic 3 speed, FX, MX, and FMX Cruise-O-Matic: 14 trans pan bolt holes.
C6TP-7000 & PDB-A = 1966 F100 MX Cruise-O-Matic w/a 352 2V.
Mitch, Ford also refered to the C4 and C6 as Cruise-O-Matics.
Old Jul 18, 2010 | 06:20 PM
Customcab's Avatar
Customcab
Bill; when I get trans pan gaskets these local computer counter guys; they ask ask if its a C-4 C-6 etc; and then I check the bolt holes to ensure I get the right pattern; expecially C-6 verse what I though was a C/M style.
Didn't know there where all consider Cruise-o-matic's; Is the one I'm calling a C/M a FMX?
Old Jul 18, 2010 | 11:28 PM
NumberDummy
Just because the pan gasket has 14 holes, does not mean it's correct, because there are TWO different types!
The MX (once known as the BIG Cruise-O) C-O-M pan has the same number of bolt holes (14) as the FX/FMX pan, but it's not the same pan, as it has a notch in it...the others do not.
The same MX pan gasket was also used in 1955/57 Thunderbirds with the Ford-O-Matic 3 speed...in fact, that's what the part number reflects.
B5SZ-7A191-B .. Pan Gasket / Obsolete
JST AUTOMOTIVE in Lebanon TN has 1 = 615-443-3086.
WESLEY OBSOLETE PARTS in Liberty KY has 19 = 606-787-5293.
GREEN SALES CO. in Cincinnati OH has 45 = 800-543-4959.
The MX trans filter is also different than was used with FX/FMX and Ford-O-Matic.
The same MX filter was used in 1965/67 F100/350 352 / 1965/67 F350 300 I-6 / 1958/67 Passenger Cars w/MX C-O-M.
B9MP-7A098-B .. MX Transmission Filter / Obsolete
High Buck! BOB ALLEN FORD in Overland Park KS has 2 = 800-676-0675.
No other Ford Dealer or obsolete parts vendor has any.
Old Jul 19, 2010 | 11:34 AM
croosteringa
yes that looks just like mine the filler tube bolts in the pan just like that one and removable bellhousing. i was told it has no filter o change just a screen you clean.
Old Jul 19, 2010 | 11:36 AM
croosteringa
yes that looks just like mine the filler tube bolts in the pan just like that one and removable bellhousing. only difference is mine has a cooler on the side
Old Mar 27, 2011 | 10:47 PM
Stockboy93's Avatar
Stockboy93
hi, im kinda confused, i have a 66 f250 it has a three speed automatic, 14 bolt pattern, can that be more that one transmission?
Old Mar 27, 2011 | 10:54 PM
Stockboy93's Avatar
Stockboy93
also, is the c4 and c6 manual transmissions? i know dumb question, haha
Old Mar 27, 2011 | 11:06 PM
85e150's Avatar
85e150
14 bolt pan in that year is a Cruise-o-Matic. Info, pictures and the pan gasket, (showing shape and bolt count) here:
Ford Cruisomatic transmission
"C4" and "C6" transmissions are Ford built 3 speed automatics, introduced in '64 and '66 respectively.
Manual transmissions for trucks are listed here:
Domestic Truck Tranny Guide
In the Ford offerings you will find Warner and New Process transmissions for pickups and mediums, with "T" and "NP" designations. Mediums also offered Clarks, but no Clarks in PU.
Old Mar 29, 2011 | 09:27 PM
Stockboy93's Avatar
Stockboy93
it is a 14 bolt pan the transmission line goes directly into the pan and i pulled the numbers off the plate, very worn, i think its right, top line fdb d the second line is 025848? my door code says the transmission is a g? not sure if its original tranny tho. very confused, thanks for the help
Old Mar 29, 2011 | 09:30 PM
Stockboy93's Avatar
Stockboy93
i also have a catalog from macs auto parts and it says my pan gasket comes from a ford o matic? im getting so many different answers lol
Old Mar 30, 2011 | 02:20 AM
NumberDummy
MX Cruise-O-Matic and some 3 speed Ford-O-Matic's use the same trans pan gasket: B5SZ-7A191-B.
See post #6.
berriault
1997 - 2003 F150
31
Dec 23, 2021 05:35 PM
1L243
Jul 26, 2016 10:24 PM
Daleksandrovich
Apr 9, 2014 02:17 PM
83fordcolebrook
Apr 24, 2010 10:34 PM
Brooksd1991
Oct 27, 2009 07:03 PM
