door seals
Old Mar 13, 2019 | 03:01 PM
greyhound's Avatar
greyhound
door seals
Hello,
I have a 1960 ford panel truck , Where is a good place to buy front and rear door seals from? I bought seals from macs years ago and put them on the truck , You could not slam the doors shut. The rubbers were no match for what I took off.At all the curves were very hard moulded rubber . You could not even squeeze them. I had to grind the moulded rubber with a die grinder to them to shut. The doors stick out a half inch all the way around the door. They were good before. Some one said soft seals were good seals but I cant find them. Thanks All for any help.
Old Mar 13, 2019 | 10:22 PM
Maltman's Avatar
Maltman
I had good luck with Dennis Carpenter seals myself.
Old Mar 14, 2019 | 12:03 AM
oldbleu's Avatar
oldbleu
I'll second that......
Old Mar 14, 2019 | 04:52 AM
greyhound's Avatar
greyhound
door seals
Thanks guys, you know how hard it is to blast the doors and primer then paint. Then when you put it all back together and it don't work, you blow a head gasket. Knowing you have to do it again. Thanks Again.
Old Mar 14, 2019 | 07:28 AM
Dennis-'s Avatar
Dennis-
I’ll agree, Dennis Carpenter Hands down. LMC sent me the wrong door rubbers twice (mounded wrong) and Dennis Carpenter was bang on first go, the rubber was softer and better quality.
Old Mar 14, 2019 | 01:39 PM
moonley's Avatar
moonley
It’s “Soffseal;” I used some but they were molded incorrectly. I emailed the company twice asking about an exchange but never even got a reply (purchased directly from Soffseal). I had to cut them apart and glue them on in several pieces so that they fit the door contour correctly.
I’ll get my next set from Dennis Carpenter.
Old Mar 23, 2019 | 10:42 AM
greyhound's Avatar
greyhound
Smile door seals
Hello All,
Thank you for all the input on the doors seals. Just got my doors seals from DC. What a big difference in the quality. Really impressed.
DW SD
24
Dec 2, 2018 11:12 AM
Y2KW57
28
May 29, 2015 02:07 PM
BrandonT71
Jun 18, 2013 03:56 PM
thrifty
Jan 15, 2013 11:19 PM
jcs1966
Mar 19, 2003 10:24 PM
