No start
Old Mar 12, 2019 | 04:32 PM
FrankTruck86's Avatar
FrankTruck86
No start
86 6.9 turns over by the solenoid but not by ignition switch. Glow plug indicator light comes on but not cycling..
Old Mar 13, 2019 | 08:08 AM
tjc transport's Avatar
tjc transport
i ain't rite
welcome to FTE.
manual trans, or automatic?
do you feel resistance and does the key pop back to run on it's own when turned to start?
Old Mar 13, 2019 | 11:12 AM
FrankTruck86
No start
It is a manual transmission. There is resistance and yes it does return to start once an attempt has been made to turn it over
Old Mar 13, 2019 | 12:27 PM
tjc transport
i ain't rite
ok. resistance and return to run means the ignition actuator is probably good. this would then point to the clutch interrupter switch on the clutch pedal assembly being bad.
Old Mar 13, 2019 | 08:55 PM
DarkOverCast's Avatar
DarkOverCast
You can test the clutch safety switch by unplugging it and sticking a fuse in the connector. That's how I have mine set up for clutchless starts. Nobody drives it but me so I don't see it as a safety issue
Old Mar 14, 2019 | 03:14 PM
FrankTruck86
There is nothing plugged into my clutch assembly. Looks like the previous owner cut it.
Old Mar 14, 2019 | 03:49 PM
tjc transport
i ain't rite
are there two wires hanging there that are not connected to anything?
they may be the wires that should be connected to the switch.
Old Apr 15, 2019 | 03:40 PM
FrankTruck86
No start
Well I got him running again. I just wanted to say thank you for your assistance. But simply put... Check and clean all electrical contact when working with older model vehicle
Old Apr 15, 2019 | 03:58 PM
tjc transport
i ain't rite
clean electrical connections are just as important for newer vehicles too since everything on them is electrically controlled.
Old Apr 15, 2019 | 04:05 PM
FrankTruck86
Lol you have a point there. But that's exactly why I like the oldie but goodies
Keith Foshee
Nov 22, 2018 06:35 AM
kavik9
Mar 8, 2016 10:34 AM
97 STILL STROKIN
Feb 16, 2012 03:31 PM
J.McConnell
18
Jan 31, 2011 09:45 PM
58Wade
Feb 15, 2006 06:29 PM
