I NEED IGNITION HELP
Old Feb 16, 2012 | 02:12 PM
97 STILL STROKIN's Avatar
97 STILL STROKIN
Question I NEED IGNITION HELP
I have a 97 F250 7.3L that does not want to start from the ignition...you can jump the selonoid under the hood and the truck will start but turing the key does nothing...all gauges lights come on but the truck wont try starting...ive already burned through two starters jumping it and replaced a solenoid...ive checked the wires all the way from the ignition to the solenoid and everything looks ok....any ideas what could be going wrong??
Old Feb 16, 2012 | 02:14 PM
docrw1's Avatar
docrw1
Ignition switch. On the side of the column is the switch. If its bad truck won't start. Also if it is a manual check the clutch safety switch.
Old Feb 16, 2012 | 02:16 PM
97 STILL STROKIN
Where is that clutch or nuetral safety swith located?? i was looking for that before and couldnt find it
Old Feb 16, 2012 | 02:19 PM
chicagodragon's Avatar
chicagodragon
is it stick or auto?
Old Feb 16, 2012 | 02:33 PM
docrw1's Avatar
docrw1
Should be on the pedal. Not mistaken it looks like a brake light switch.
Old Feb 16, 2012 | 02:39 PM
97 STILL STROKIN
its an automatic
Old Feb 16, 2012 | 02:46 PM
docrw1's Avatar
docrw1
If not mistaken they where on side of transmission where linkage is.
Old Feb 16, 2012 | 02:49 PM
Hussler's Avatar
Hussler
Will it start when in neutral ?
Old Feb 16, 2012 | 03:05 PM
97 STILL STROKIN
No it wont start in nuetral or park...one other person told me it could be the 303 relay but i have no idea what that is or where it is
Old Feb 16, 2012 | 03:31 PM
Hussler's Avatar
Hussler
No 303 relay on these rigs.
1996 Bronco/F-Series Workshop Manual
Click on Engine -> Starting Systems -> Electrical Schematics
Also has some pin point tests that might help you out.
444fan
Jul 12, 2018 06:36 AM
billpct
Feb 1, 2011 09:28 AM
bobbyb61b
Dec 27, 2010 06:31 PM
mark8881
1997 - 2003 F150
Oct 19, 2008 02:10 PM
fordman93
Electrical Systems/Wiring
Feb 22, 2004 02:45 PM
