Harmonic Balancer Install - Questions
Old Feb 26, 2019 | 06:25 PM
Gigemags05's Avatar
Gigemags05
I watched a few videos and installed my harmonic balancer using an install tool.
I just installed the balancer with a little touch of motor oil and went til it wouldn't go on anymore.
1.) Should I have used RTV or sealant? Do I need to remove and re-install? I see varying opinions on this, but would like to remove all doubt.
2.) How do I know that the balancer is on all the way? Is there a reference I can use?
Old Feb 26, 2019 | 06:30 PM
Franklin2's Avatar
Franklin2
You should have a center bolt with a washer that holds it on there. When you tighten that, the washer will push it back till it's flush with the front of the crankshaft. Put the large washer on the bolt, and then put some rtv on the washer to seal off the end of the crank. You can get oil going by the keyway if you don't and it will leak oil.
Old Feb 26, 2019 | 06:48 PM
Gigemags05's Avatar
Gigemags05
Ok, so just put some rtv on the washer? I don’t need to remove the balancer and put some on the key way
Old Feb 26, 2019 | 07:03 PM
matthewq4b's Avatar
matthewq4b
Ya I would just pull the balance back and just put a smear on the bore of the balancer and in the key then bolt it back in. I'm not fan of smearing silicone on the washer as you have to also do it under the bolt head. And there are no guarantees it will seal. And it is kinda a hack way to do it.
Old Feb 26, 2019 | 07:05 PM
Gigemags05's Avatar
Gigemags05
Seal is brand new, it should still be good shouldn’t it?
Old Feb 26, 2019 | 07:06 PM
matthewq4b's Avatar
matthewq4b
Yes it will be fine.
Old Feb 28, 2019 | 12:08 PM
Franklin2's Avatar
Franklin2
The rtv will ooze in around the bolt head and the end of the crankshaft. If you look closely you will see the factory had some sort of sealer there also.
Old Feb 28, 2019 | 03:03 PM
matthewq4b's Avatar
matthewq4b
The factory uses sealant on the inside of the balancer, when the balancer is drawn on it is forced out the end and ends up around the bolt/washer. The factory procedure is to use RTV inside the balancer this makes sure it does not end up in the sump.
fordboy300
18
Feb 9, 2020 12:30 PM
mountain dewd
Sep 23, 2016 11:06 PM
Bagbyknoter
Nov 24, 2011 02:38 AM
MBBFord
Jun 26, 2006 05:24 PM
blackokc
1978 - 1996 Big Bronco
Nov 19, 2001 09:10 PM
