1978 - 1996 Big Bronco
Harmonic Balancer removal
Old Nov 16, 2001 | 08:34 PM
blackokc's Avatar
blackokc
Post Harmonic Balancer removal
I am having a hard time removing the harmonic balancer on my 93 Bronco (302). I have been unable to budge it with a puller. Someone suggested that I remove the radiator for clearance, and then with a sledge hammer strike the center bolt of the harmonic balancer puller while under tension. So far no luck. Any suggestions?
Steve B.
OKC
Old Nov 17, 2001 | 09:42 AM
SBV1's Avatar
SBV1
I don't mean to insult your intelligence. Did you remove the bolt first? If yes, after applying liberal amonts of penetrating oil, then while having tension on the puller, use a series of firm raps, like an impact hammer instead of a few hard hits.
Old Nov 18, 2001 | 07:15 PM
blackokc's Avatar
blackokc
Yes, I removed the bolt first, but funny you should ask. The space that the bolt was in had been caked with mud. When I removed the bolt, I didn't notice the LARGE mud covered washer underneath it. The puller worked so much better without that there washer in the way.
Thanks for the help.
Steve B.
Old Nov 19, 2001 | 12:12 AM
lvstang's Avatar
lvstang
>Steve B.
Glad you got it!!! It happened to me also. Broke my dang puller.
Old Nov 19, 2001 | 09:10 PM
JBronco's Avatar
JBronco
wfo1955
Mar 6, 2016 02:19 AM
dmueller71
Dec 18, 2010 10:49 AM
broke4now
1983 - 2012 Ranger & B-Series
Mar 23, 2010 07:30 PM
kcone
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Aug 16, 2004 01:50 AM
ronca2
Mar 3, 2004 10:11 PM
