ScanGauge XGAUGE Programming
Old Feb 24, 2019 | 10:17 AM
Martin Torres's Avatar
Martin Torres
Hiall,
Recently purchased the ScanGuage II to help track down an issue I was having (resolved now) but I am going to mount it for real time monitoring. I found a crap load of posts with programming codes but they are intermixed between 7.3 and 6.0. Some odes for the same functions have different values. Been trying them but it seems I am only getting about a 50% success rate on working codes. Does someone have a link to a post or webpage specifically for the 7.3 tested codes to eliminate the codes that don't work? My truck is a 2003 7.3 F350.
Old Feb 24, 2019 | 01:32 PM
JT250's Avatar
JT250
I know some who use scan gauge but I there has been a lot more info provided to Torque Pro.
Old Feb 25, 2019 | 06:50 AM
Tugly's Avatar
Tugly
Everybody is focused on Torque Pro nowadays, so maybe you can get some clues from Torque Pro formulas.
Old Feb 25, 2019 | 08:46 AM
arcticatdan's Avatar
arcticatdan
Here are some or the x codes:
Coolant Temp:
TXD: C410F1221139
RXF: 046205110639
RXD Engine: 3008
MTH: 00010002007F
NAM: ect
The value displayed by this XGauge is only valid after the coolant temperature gets above 127* F. Before the engine is warmed up the displayed value will go up to 255 this about double actual then start over at 127. This is becasue this PID is scaled for two different ranges. It works good on my 2000 7.3 and seems to be accurate. This has been a long sought after XGauge for the 7.3 crowd for quite some time.
Glow Plug Percent:
TXD: C410F1221430
RXF: 046205140630
RXD: 3008
MTH: 0F5127100000
NAM: gp%
This is a good way to see how long your glow plugs are staying on. They will stay on for quite a while after the engine is running and the glow plug (wait to start) light has gone out.
Engine Oil Temp:
TXD: C410F1221310
RXF: 046205130610
RXD: 3010
MTH: 000901F4FFFD8
NAM: EOT
IPR Duty Cycle:
TXD: C410F1221434
RXF: 046205140634
RXD: 3008
MTH: 006400FF0000
NAM: IPR
Injection Control Pressure:
TXD: C410F1221446
RXF: 046205140646
RXD: 3010
MTH: 003800640000
NAM: ICP
Exhuast Back Pressure:
TXD: C410F1221445
RXF: 046205140645
RXD: 3010
MTH: 016C03E80000
NAM: EBP
Transmission Fluid Temp: (This one is already documented in their XGauge Ford PWM section)
TXD: C410F1221674
RXF: 046205160674
RXD: 3010
MTH: 000100080000
NAM: TFT
Old Feb 25, 2019 | 02:23 PM
Bently_Coop's Avatar
Bently_Coop
Scangauge website has a link for X gauges with all codes available.
https://www.scangauge.com/x-gauge-commands/7-3l-diesel/
gblinkey
Mar 20, 2019 10:45 AM
MAKO314
Jan 15, 2019 07:43 PM
Jacky Dude
Nov 14, 2017 10:15 PM
4inchlovin
May 6, 2009 05:08 PM
4inchlovin
39
Apr 24, 2009 03:31 PM
