Parameters
Parameters
So as most of you know i ordered some digital gauges for my truck. I need to set parameters for pretty much every vital stat. If yall could help that would be good.
I need.
EGT:
coolant temp:
engine temp:
oil temp:
i need a high and low for battery voltage:
and anything els yall can think of...
heres the list of what the gauge does from my previous thread...
Thanks Guys!!!!
I need.
EGT:
coolant temp:
engine temp:
oil temp:
- A1C-Ford Powerstroke Supported Parameters (PID'S)
- INTAKE AIR 2- Intake Air Temperature taken at the throttle body inlet
- COOLANT TEMP 2- Engine Coolant Temperature
- RPM 2- engine Revolutions Per Minute
- MANIFOLD kPa- Manifold Air Pressure (kPa)
- BOOST – Boost Pressure
- MILES PER HOUR 2- Miles Per Hour
- TRANS TEMP- Transmission Temperature
- BATTERY VOLTAGE- Alternator/battery output voltage
- PULSE WIDTH- injector pulse width in msec.
- ENGINE OIL TEMP
- EX. BACK PRESS – Exhaust back pressure
- ICP DC – Injector Control Pressure Duty Cycle
- ICP – Injector Control Pressure
- INJ. TIMING – Injector Timing Deg BTDC
- CURRENT GEAR – Current Transmission Gear
**NEW** User selectable logo. Choose From: Generic, Cobra, Lightning, MACH 1, Marauder, Harley, Mustang, and TBird.**NEW** Annunciator feature allows shift lights to be used as warning lights. Set any parameter to trip the lights above or below a preset value. Perfect as a trans temp, coolant, or oil pressure warning.**NEW** Universal code works on all 96-03 Fords. User selectable paramaters allow only the specified parame
Thanks Guys!!!!
LARIAT 85
05-12-2009 04:28 PM
4inchlovin
39
04-24-2009 03:31 PM
SeminoleSlim
25
07-15-2008 10:32 PM
kc135cruechief
06-15-2007 05:55 PM
