Aftermarket Remote Keyless Entry
Old Feb 21, 2019 | 02:20 PM
Markus Luukko's Avatar
Markus Luukko
I am working on installing an aftermarket keyless entry system on my truck.
In my head,
I have the idea of only needing to attach 4 wires, as the whole lock/unlock circuit is connected.
Here is the wiring connector for the driver door unlock/lock switch.
If supplied power to the new junction box with constant 12V
Supplied Ground
And connected the two wires that came off the junction box, one for unlock and one for unlock the circuit should be completed right?
Just wanted to see if anyone else has done it, or if someone whos better than wiring than me has any input.
Thanks.
Old Feb 21, 2019 | 02:45 PM
bman661's Avatar
bman661
I am gonna be watching this one, I tried to install aftermarket RKE a few months ago and couldn't get it to work. Eventually it started smoking and melted the wires, I hope somebody has some info on this! I was using the same wires pink and light green and pink and yellow, but the wiring configuration on the key less entry module is where i struggled to get the wiring right.
Old Feb 21, 2019 | 09:06 PM
Markus Luukko
Tried everything I could and nothing worked, found online that the signal from the box isn’t strong enough for the actuators to work. I am going to pay someone to install everything.
Old Feb 21, 2019 | 09:23 PM
bman661's Avatar
bman661
I will most likely do the same thing! I had a hell of a time with it.
Jkamiy
Jul 15, 2017 10:02 AM
chrismd188
Jan 29, 2017 11:57 AM
wr310rdr
Jul 22, 2013 12:09 AM
kahunaman2
17
May 22, 2004 09:02 PM
branded212
Feb 16, 2004 04:48 AM
