Wiring remote keyless entry on a 94.5
I managed to come up with a aftermarket remote keyless entry for my 94.5 F-250 and need to know if anybody has a wiring diagram so I can hook this thing up. I'm tired of locking the keys in the cab!
Thanks,
Don Johnson
'94 F-250 Where the Powerstroke started!
Thanks,
Don Johnson
You can buy the service manual on ebay fairly cheap on CD. I have on for both 97 and 2000. If I can look anything up let me know, It should be close on my truck.
About two years ago I installed a Ford oem system on mine and used the diagram and service manual. Its no easy bolt on and not for faint at heart. You need to cut and splice wires.
A good voltmeter will be your best freind in the install. Take that back, a must have!!
check out this site http://www.bulldogsecurity.com/ you'll probably need 2 5post relays if your aftermarket kit doesn't have them built in. your truck has type-c door locks so you need to find the lock and unlock wires(pink/yellow, pink/lt green) at drivers kick pannel. cut both these wires in half use a test light to find the switch side on the wires(lights when lock button pressed) wire the relays as follows
switch side(pin 87a) motor side(pin 30) constant 12V(pins 87& 85) and negative input from keyless module(pin 86) if the module uses a positive output ground pin 86 & hook output wire to pin 85
if you need a diagram e-mail me fsajm11@uaf.edu and i'll send you one follow these steps for the unlock and lock wires and it should be a piece of cake!!! good luck
