3 on the tree
Old Feb 14, 2019 | 08:47 PM
slabhunter's Avatar
slabhunter
3 on the tree
I think I might like to move my 3 on the tree to a floor shift in my 61 F100. Anybody ever made this switch? What shifter will fit?
Old Feb 15, 2019 | 12:19 AM
Christmas's Avatar
Christmas
I don't see how that is possible, the shifter body would need to mount on the trans not just the floor. Seems easier to just install a top loader.
Old Feb 15, 2019 | 08:19 AM
Inline66's Avatar
Inline66
This has been done many times on later trucks, and I believe it's just as easy on yours. I used a Hurst Indy shifter made specifically for this purpose on my 66. You would just have to search for a shifter that works with your 61.
Old Feb 18, 2019 | 06:40 AM
Srowe's Avatar
Srowe
I am looking to convert my 3 on the tree to an automatic trans with the column shift,
any thoughts on this swap?
Thanks
Scott
Old Feb 18, 2019 | 11:34 AM
RangerMercMan's Avatar
RangerMercMan
Mustangs 65-66 had 3 speed manual trannys with floor mounted shifters
Old Feb 18, 2019 | 04:49 PM
Inline66's Avatar
Inline66
Thanks
Scott
That's a lot more involved. You'd need a different column, carb/kickdown connections, trans cooler, swap from flywheel to flexplate/TC, possibly different driveshaft length... Maybe more I'm not thinking of.
Old Feb 18, 2019 | 04:53 PM
cosmofennema's Avatar
cosmofennema
Welding/fabrication skills, some electrical knowledge, definite driveshaft modification, possible custom bellhousing, it's a LOT of work, make sure you have the knowledge before you create a parts truck.
Cosmo
Puro_tkt
Nov 7, 2011 04:03 PM
Pappys53
Jul 31, 2009 01:05 PM
ggadwa
Nov 12, 2007 05:01 AM
cva6633
Sep 7, 2006 07:51 PM
deronyv8
Oct 13, 2002 05:42 PM
