Hood Insulation
Old Feb 18, 2019 | 08:51 PM
  #31
TCNashville's Avatar
TCNashville
Hmmm. My '17 STX/XL does not have one. Mines a gasser so engine produces less heat to affect the paint?
Old Feb 19, 2019 | 05:40 AM
  #32
delorenzomp's Avatar
delorenzomp
Originally Posted by Chrislorl6211
I am considering adding this. Taska has it at about $70.00 but shipping is showing $161.00?????
Any suggestions?
it must be geographic, POSSIBLY, I chose to purchase online for the ease of getting it, my dealer’s hours are pretty-much the same as mine. The cost of the blanket is pretty-much the same, $63-$70, the freight varied from $109-$167, then just Googling the part number I came upon a dealer in my state 2-1/2 hours away, Crossroads Ford in Ravena NY, $16 shipping ! Here’s the thing, Group 1 in the midwest was $109, Tasca in RI $167, Tasca is maybe five hours from me??...maybe they ship it flat in a crate and Crossroads rolls theirs... maybe give them a try...Josh helped me, jclements at Crossroads Ford. Good luck!
Old Feb 19, 2019 | 10:15 AM
  #33
wrvond's Avatar
wrvond
Originally Posted by delorenzomp
wrvond- do you recall if your under hood LED light is run under the insulation with aN insulation cutout for the fixture to protrude through? Or is the LED light fixture wiring run over the blanket ie the blanket was installed first...thanks!
Sorry, just now saw this. I'm thinking my wiring is above the blanket, but can't swear to it. Drove the car to work today so will have to check tonight to be sure. I'll let you know what I see.
Old Feb 19, 2019 | 10:44 AM
  #34
delorenzomp
no problem, thanks
Old Feb 19, 2019 | 02:15 PM
  #35
xxxsherpa's Avatar
xxxsherpa
'17 XLT 6.2 I have insulation with the light wiring on the outside of the insulation.
Old Feb 19, 2019 | 02:23 PM
  #36
wrvond's Avatar
wrvond
That's three so far with wiring on the outside. I wonder why they did that? Makes more sense to me to install the light, then the blanket. My memory being what it is (or isn't), I'm sure I'll get home and find the wiring on the outside too. I just have to check to be sure.
Old Feb 19, 2019 | 02:29 PM
  #37
delorenzomp
I am pretty sure I will install mine without moving the light and wiring, either over it or I'll cut a slit for future access.
Old Feb 19, 2019 | 03:30 PM
  #38
xxxsherpa's Avatar
xxxsherpa
Looks like the light and wiring have clips to remove them as needed.
Old Feb 19, 2019 | 03:43 PM
  #39
delorenzomp
the light definitely does, I fumbled with it a bit but it was single digit temperature so I gave up rather quickly. I will give it a serious attempt at a later time.
Old Feb 19, 2019 | 10:26 PM
  #40
wrvond's Avatar
wrvond
Mine is on the outside too, but not in the way I was expecting. There’s only about a six inch span where the wire is actually over the insulation. There’s only one clip between the light and the first clip that is outside the edge of the insulation.
Old Feb 19, 2019 | 10:43 PM
  #41
kry226's Avatar
kry226
Can anyone confirm if their 2019 6.2 XLT Premium has the insulation?
Old Dec 26, 2019 | 10:37 AM
  #42
PENOBSCOT's Avatar
PENOBSCOT
For the guys that added the hood insulator, did you notice a difference in noise after the install?
Old Dec 26, 2019 | 12:10 PM
  #43
delorenzomp
Can’t say that I have, but I added mine to mainly (hopefully) To slow the aging of the painted exterior surface by shielding it from excessive heat.
Old Dec 26, 2019 | 01:19 PM
  #44
speakerfritz's Avatar
speakerfritz
Originally Posted by BlackSTXFL
Do we need these on our trucks because I don't think they gave me one. Is it to keep stray cats warm in the winter?
no wonder I can’t hear the diesel Chaka-chug sound....mine has the insulation also.
Old Dec 26, 2019 | 06:12 PM
  #45
PENOBSCOT's Avatar
PENOBSCOT
Thanks for the replies.
