Poor MPG
Old Mar 6, 2019 | 04:51 AM
  #166
Flyboy1100's Avatar
Flyboy1100
Originally Posted by BatteriesNotIncluded
Tested for voltage. Seemed good when compared to known good plug connector.
Scanned again afterward and now #10 is showing value of 0.90% so it's limit isn't being tipped at >=1.43% anymore. Not misfiring anymore according to mode $06, although minor vibes still possibly present at idle. I say possibly as I don't know if I'm being overly sensitive to it now.
So strange. Compression issue maybe?
More soon when I've run through this tank.
Appreciate everyone's contributions to this long *** thread.
mine isn’t always perfectly smooth either
i suppose it’s possible reseating everything may have fixed a poor connection, definitely continue to monitor it for a few more days.
Mode $06 is a great tool, but at the same time it isn’t perfect and rough roads can sometimes be translated as low % misfires, but with the higher % you were seeing those were definitely misfires.
also every engine will miss occasionally, so I wouldn’t fret the real low %, just when it crosses the 1.4% threshold
whats your injector pulse width reporting? Those things fire so quickly it would be hard to hear if it was lazy. Not sure that could tell you anything or not, as it doesn’t report individual cyl.
Have you run some good cleaner through the tank along with a high detergent fuel, ie shell? Gumout all in one or gumout regain??? Even berrymans b12 is great. I personally don’t like Seafoam
Old Mar 6, 2019 | 07:51 AM
  #167
BatteriesNotIncluded's Avatar
Not sure what the injectors are reporting just yet. If I had Ford's IDS I'd love to see their relative flow report...
I've added three cans of Seafoam and one bottle of O'Reilly's own fuel cleaner as it was on offer. I'm all up for trying Gumout on the next tank though (do you follow their instructions on putting it on near empty tank and only fuel up 19 gallons?)
Will report back with a pic later showing a frayed braided cable. Wondering if this is my issue...
Old Mar 6, 2019 | 09:12 AM
  #168
WE3ZS's Avatar
WE3ZS
The frayed braided cable would be one of the grounds, bad grounds can cause all sorts of odd electric behavior. Best to clean up and or replace any suspect grounds.
How does it appear this tank is doing following the plug change so far?
Old Mar 6, 2019 | 10:58 AM
  #169
Okay. I looked at my data again and realised I'm getting values on all cylinders on the driver's side and nothing on the passenger. I went and did a visual. Didn't touch a thing. Scanned it:
I got codes PO356 & PO360. No CEL.
Forscan tells me it's an open ground, just like you say Tom. These codes just got thrown up as of this morning.
I opened the braid of that cable from where it's fraying and the cable insulation itself is intact. I've wrapped it with 400F heat shield tape to protect from where it wore against the manifold:
Code persists after clearing, so issue must lie elsewhere. It's gotta be the wiring as 4 out of 5 cylinders are being affected on the driver's side. Is the above cable the ground (if so, the only ground for driver side?)
I'm at half tank with 120 miles on the odometer. Expecting more than 240 though of course given how first half always races and then slows for second half.
Old Mar 6, 2019 | 01:51 PM
  #170
Flyboy1100's Avatar
Flyboy1100
Well your issues are all on the side with the bad ground, fix the ground!
Old Mar 6, 2019 | 01:54 PM
  #171
I hear 'ya, just not sure how. As above, is that braided cable the ground?
Old Mar 6, 2019 | 04:28 PM
  #172
Flyboy1100's Avatar
Flyboy1100
not sure, currently 600 miles away from mine and my service manuals
does the end of that cable connect to engine/frame??
there are also ground cables from engine to frame in the back of the engine i think, most vehicles hsve them.
Old Mar 6, 2019 | 04:43 PM
  #173
you can see it wrap around the manifold and plug back in. Doesn't look like a ground to me.
Old Mar 6, 2019 | 06:19 PM
  #174
Flyboy1100's Avatar
Flyboy1100
That might be oil pressure switch wire (just replaced mine yesterday coincidentally)
check the ground straps and any ground you can find
Old Mar 6, 2019 | 09:29 PM
  #175
I think you're right. Does anyone know where the ground strap for the driver's side coils is?
Old Mar 7, 2019 | 09:25 AM
  #176
96firephoenix's Avatar
96firephoenix
I think it's back of the block, going to the firewall next to the brake booster.
Old Mar 7, 2019 | 03:49 PM
  #177
Okay, I took it to a shop.
They kept it all morning. Couldn't find an issue.
They saw the codes and cleared them before their test drive. Took it out for 45 minutes driving whilst monitoring cylinder contribution results. No misfires.
They came back and did a visual, all okay. Also handled and wiggled all harnesses and connectors for anything loose. They had hands over a lot of different things.
Didn't charge me a penny when I collected.
Here's what Forscan threw up though on it's return:
Misfire Rate & Type A Threshold, Cylinder 1
TID: 53
CID: 1
Value: 0.00 %
Limit: <= 19.58 %
Misfire Rate & Type A Threshold, Cylinder 2
TID: 53
CID: 2
Value: 0.00 %
Limit: <= 19.58 %
Misfire Rate & Type A Threshold, Cylinder 3
TID: 53
CID: 3
Value: 0.00 %
Limit: <= 19.58 %
Misfire Rate & Type A Threshold, Cylinder 4
TID: 53
CID: 4
Value: 0.00 %
Limit: <= 19.58 %
Misfire Rate & Type A Threshold, Cylinder 5
TID: 53
CID: 5
Value: 0.20 %
Limit: <= 19.58 %
Misfire Rate & Type A Threshold, Cylinder 6
TID: 53
CID: 6
Value: 0.00 %
Limit: <= 19.58 %
Misfire Rate & Type A Threshold, Cylinder 7
TID: 53
CID: 7
Value: 0.00 %
Limit: <= 19.58 %
Misfire Rate & Type A Threshold, Cylinder 8
TID: 53
CID: 8
Value: 0.00 %
Limit: <= 19.58 %
Misfire Rate & Type A Threshold, Cylinder 9
TID: 53
CID: 9
Value: 0.10 %
Limit: <= 19.58 %
Misfire Rate & Type A Threshold, Cylinder 10
TID: 53
CID: A
Value: 0.10 %
Limit: <= 19.58 %
Highest Type A Misfire Rate & Threshold
TID: 54
CID: 0
Value: 0.39 %
Limit: <= 19.58 %
Highest Type B Misfire Rate & Threshold
TID: 55
CID: 0
Value: 0.12 %
Limit: <= 1.43 %
Cylinder Events Tested
TID: 56
CID: 0
Value: 6792.00
Limit: <= 5000.00
The values on 6-10 have changed as well as the limits on all cylinders. Code has not returned. does this mean an electrical gremlin persists somewhere if their wiggle test has affected these results? What about that "Cylinder Events Tested" value?
Currently sat between 1/4 and 1/2 full tank with 145 miles on the clock. Last time I reported that needle range up the thread some I had 185 miles before the plug swap...
This beast baffles me. That said, I'm not going to pass too much judgement on this tank, seeing as it's now skewed (plugs swapped at 1/4 gone, misfire on 10 for a few days... etc...)
Would resetting the PCM help any?
Old Mar 7, 2019 | 07:20 PM
  #178
Flyboy1100's Avatar
Flyboy1100
The cylinder events tested is just a counter, it doesn’t mean anything
like i said, every vehicle has a few random misfires, thats ok, its when you start seeing those higher percentages you have a real problem.
And mode $06 is super sensitive, false knock from a big bump can be interpreted as a misfire, so again those tiny percentages are nothing.
Old Mar 7, 2019 | 08:51 PM
  #179
Got it.
Any thoughts about the PCM reset?
Old Mar 7, 2019 | 11:16 PM
  #180
Flyboy1100's Avatar
Flyboy1100
Got it.
might make it relearn faster but I don't think it will "fix" anything. I also don't think it could hurt much either. go for it
