Poor MPG
Old Feb 12, 2019 | 04:27 PM
  #31
WE3ZS's Avatar
WE3ZS
Originally Posted by BatteriesNotIncluded
Got it, will do. Last refill was to full, the receipt says it was a 35 gallon fill up. At every refill, I reset the trip odometer - a habit I've been doing for years.
Y'all are great. Really appreciate this community
Originally Posted by agsmv1
How did you come up with 4.5mpg? Hand calculated?
Sure is. 200 miles to my last full tank.
Originally Posted by WE3ZS
You went 200 miles and then pumped 44.4 gallons of gas into the tank?...............Is your 4.5 truely hand calculated by dividing the miles driven by the gallons pumped to refill the tank? I have only once ever pumped over 44 gallons into mine and it was basically on fumes.
Yessir - but I'm now holding judgement as I do the same calculation on the next two full tank fill-ups. to get my 3 x average MPG.
Well, your mileage is already improving........... 200 miles divided by 35 gallons equals 5.71 MPG, that's over 20% better (actually it's 27% better!) than your initial number of 4.5 MPG. Of course, it's still horrible so we will continue to come up with ideas to help and now I'm looking forward to the numbers from the next fill up.
Old Feb 12, 2019 | 04:41 PM
  #32
BatteriesNotIncluded's Avatar
Yeah, in finding that receipt it revealed a modicum of a better reality haha.
I'm looking forward to the new numbers too. Thanks Tom.
Old Feb 12, 2019 | 04:57 PM
  #33
PrescottIce's Avatar
PrescottIce
I'm going with either horribly plugged cats or the fuel theft theory. Watching with great interest, as other than this instance, I'm thinking V10s are a great investment.
Old Feb 12, 2019 | 06:22 PM
  #34
inthedirt's Avatar
inthedirt
Do you have a locking fuel cap?
Old Feb 12, 2019 | 08:59 PM
  #35
I don't, but I honestly can't imagine this is the issue...
I live on a quiet street, in a small suburb.
That said, I will check my parking mode Dash Cam to see if there's any suspicious activity.
Old Feb 12, 2019 | 09:36 PM
  #36
Vinny G-the EX man's Avatar
Vinny G-the EX man
iIn my 39 years of experience in law enforcement, quite streets are the most desirable for criminals as they try not to be seen so I wouldn’t automatically assume it’s not happening. Do you think that the trip odometer is malfunctioning? Keep us informed, someone will solve the problem.
Old Feb 12, 2019 | 10:35 PM
  #37
In the interest of ruling out possibilities, I've ordered a locking fuel cap from Amazon. Will be here in two days time.
One thing I should nominate, I can visibly see the fuel needle drop even on relatively short... ahem... excursions. Like 1/8th - 1/16th movement for a 15-20 mile journey.
Old Feb 12, 2019 | 10:44 PM
  #38
Flyboy1100's Avatar
Flyboy1100
1/4 gone = 70mi for me or 7 gal
1/2 gone= 180mi, or 18 gal
3/4 gone= 300 miles for me, or 30 gal
7/8 gone = 380 miles, or 38gal
I'm well below E before it's empty, never tried it, most i have put in was 40, but mine is horrible throughout entire range, but it is consistent
the fuel guages suck, don't look at visible drop
also these trucks qualify for heavy truck emissions, OBD1 standards stuff. don't assume because you don't have a check engine light, everything is good. put is this way, you can have a misfire (personally ran on 8/10 for a few miles once) and NO check engine light. that can really affect MPG too.......
Old Feb 13, 2019 | 10:01 AM
  #39
With that in mind, if I bought a cheap hand scanner would it show these 'no-warning codes'?
Old Feb 13, 2019 | 01:44 PM
  #40
1 Excursion camper's Avatar
1 Excursion camper
no! Unless it is a California emissions vehicle. Those have OBDII software. Other like my 02 run OBDI software. It will not set a misfire or check eng light. But it will flash OD if it’s misfiring.
FWIW the first 1/4 tank from full will go fast due to the design of the tank. The rest of the 3/4 tank will go at the same rate.
Old Feb 13, 2019 | 02:13 PM
  #41
I think it is Cali emissions. It has a sticker on the inside of the hood declaring it as so.
Old Feb 13, 2019 | 06:36 PM
  #42
Flyboy1100's Avatar
Flyboy1100
need access to mode $06 data. Forscan works great with my obdlinkmx adapter
a cheap reader will read o2 data etc, but none of the more advanced stuff
when i had misfires i had no indication other than sound/lack of power/ raw fuel smell. No OD light blinking, but mine is a 2000
Old Feb 14, 2019 | 09:23 AM
  #43
96firephoenix's Avatar
96firephoenix
Wait... what? 49state versions have obd1?
Old Feb 14, 2019 | 09:28 AM
  #44
1 Excursion camper
Yep federal emissions on anything over 8600lbs is considered heavy duty and doesn’t have the same emissions standards. I do believe today’s vehicles that has changed. But back in the early 2000’s that’s the way it was.
Old Feb 14, 2019 | 09:55 AM
  #45
WE3ZS's Avatar
WE3ZS
Right, it's the OBDII platform (PCM, sensors, harnesses and under dash port) but it's running earlier OBDI software due to the weight and EPA rules at the time of build. Even a lot of inspection shops are unaware of this and will fail rigs as showing "not ready", they will never be ready with OBDI data!
