Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
N600 Shift Boot
Old Jan 24, 2019 | 09:58 PM
darrellpod's Avatar
darrellpod
N600 Shift Boot
Does anyone know if there are any shift boots for the cab of a 1964 N600? After driving around winter with the large air vent in the floor from the missing one in my truck, I fabricated one from a cut up inner tube with some rubber patch cement and some creative cutting of it. Looks like crap but does the job for now. The only one I can find that will fit the large hole in the floor is from an International truck but will have to neck down the hole for the stick as it is too large (not a big issue), but would rather find one for the truck.
Appreciate any help or maybe someone has pictures of an original one that I could get an idea as to what it looks like.
Old Jan 24, 2019 | 11:30 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The type of trans is...?
Old Jan 24, 2019 | 11:35 PM
85e150's Avatar
85e150
OP says 4 speed with 2 speed axle in his earlier post.
Old Jan 25, 2019 | 06:51 AM
darrellpod's Avatar
darrellpod
It has the 4 speed transmission (CODE: A). I think it is a NP-435.
Darrell
Old Jan 25, 2019 | 04:05 PM
NumberDummy
A: New Process 435 4 speed = 1964/65 500 and larger series trucks; 1966/89 all.
C3TZ-7277-G .. Gear Shift Lever Boot / 11.85" long; 7 1/2" wide; 6.82" recessed height / Obsolete
1963/69 N500/750 (gas) all M/T's.
No Ford dealer or obsolete parts vendor has any, none on ebay.
See upper right in pic:
Old Jan 25, 2019 | 04:32 PM
darrellpod's Avatar
darrellpod
NumberDummy - thanks much for the information. Although there is no replacement available, it gives me an idea as to what it should look like. The one I made is inverted to raise up into the cab instead of taking the space between the floor and the transmission. I guess I could turn it over and it would look less ugly below the floor than above it
Old Jan 25, 2019 | 06:25 PM
wharthog's Avatar
wharthog
Glad you asked that question. I will be building a new one for my truck too. I like the idea of inner tube rubber. It is great to see the original prints so it can help in the process of designing one. I was under the impression mine had slipped down into the opening.
Old Feb 12, 2019 | 02:23 PM
bhain's Avatar
bhain
I am in the same boat, apparently they are hard to come by. I am working on a fix and will post a pictures if it turns out to be useful.
Sixoh
20
Jan 24, 2016 05:52 PM
sgg93
25
May 25, 2012 05:31 AM
dullchrome
Jan 26, 2009 04:57 PM
sancochojoe
Apr 16, 2005 07:54 AM
KJB
Nov 7, 2001 06:55 PM
