Does anyone know where I can find a transmission shift boot for my 63 with a four speed manuel? I purchased one from BlueOval but it does not seal to the floor, it covers were that stick enters the trans. I still have a huge hole in the trans cover area. Here is a link to the part that I already purchased.
The bottom diameter is 5 inches, height is about 4 inches and I have no idea how many folds, I dont have the original boot. ( there was a huge piece of **** carpeting stuffed in there when i got the truck...LOL ! )
LOL...**** rug...that goes back a bit...LOL...as to the creases...I mean the new boot you got...Im 99% sure of its application...number of creases will confirm...
It has the base, two folds and then the snout where the shift lever goes through it. Here is a link to Blueovals web page with the part on it shift-lever-boot-4spd-od
Ive only seen that particular boot on 65 and 6s with NP gearbox...the later ones are smaller base dia. and a taller overall ht from what Ive seen...but with clutches coming and going anything is possible :-)
Ive only seen that particular boot on 65 and 6s with NP gearbox...the later ones are smaller base dia. and a taller overall ht from what Ive seen...but with clutches coming and going anything is possible.
Not sure if answers the question, but with my T18 4 speed the boot came with a retaining ring. Periodically hose it down with 'tirecare' wipe off and good for another 100,000. The boot has a base the retaining ring sets onto and the ring is secured to the transmission tunnel. Would think the ring would be easy to fabricate.
