Dealer changed tank size..now problems
Old Jan 24, 2019 | 06:59 PM
SkiLef's Avatar
SkiLef
So I brought my truck to the dealership yesterday to have them change my fuel tank size since I just had a bigger tank installed. That went fine until I got in my truck and was headed home and noticed I was missing a bunch of options on my dashboard screen and it wouldn't even allow me to click on "truck apps". I brought it back today to have that changed and fixed and I left there without 4WD, traction control, airbag light on and volume on steering wheel not working. So where do I go from here? Headed back there in the morning but would like to have some kind of idea what to do..
My truck is tuned and deleted with PPEI tunes and EZ LYNK software. Appreciate any help in advance.
Old Jan 24, 2019 | 08:05 PM
Just Strokin's Avatar
Just Strokin
Did you "un-tune" your truck before letting the dealer make these changes?
Old Jan 24, 2019 | 08:27 PM
ford390gashog's Avatar
ford390gashog
Its because they are using as built values from a different truck. What size tank did you install? Probably easier to do it yourself with forscan.
Old Jan 24, 2019 | 08:50 PM
Just Strokin
FORScan changes the same parameters as does Ford IDS when they change tank size. They do not load new AB data to make tank size changes.
The reason I asked if he "un-tuned" his truck was just in case they updated the PCM to the latest Ford IDS calibration. This would over write his custom tune he has loaded.
Old Jan 24, 2019 | 09:47 PM
SkiLef's Avatar
SkiLef
I didn’t untune as i figured i would just reload my tunes on if i had any problems. So which steps should i take now? How can i get him to just program it back to wherever it was and have all that stuff work? Then i will just loads my tune on top of it. Not to mention, when i get there tomorrow should i go into EZ Lynk and flask back to stock or what? Didn’t know it was a option to be honest. Feel free to text me at 16163043742 if it’s easier and quicker.
Old Jan 24, 2019 | 09:49 PM
ford390gashog
All the functions he is missing are controlled by the same program line. I find it odd they don't work. Some dealers have been known to get confused and attempt to pull AB from the motorcraft service content website with a alternative vin number and try the manul entry in IDS and then things get interesting. Technically you do have to manipulate the AB because the value you are trying to change to wasn't what the truck was built with.
720-01-02 B9CB
B*** 4x2, 4x4 Indicator, Productivity Screen (Enable)
3*** 4x2, 4x4 Indicator, Productivity Screen (Disable)
*C** Welcome Mode (Disable)
*D** Welcome Mode (Enable)
*E** Welcome Mode (Disable)(Dually)
*F** Welcome Mode (Enable)(Dually)
*8** Welcome Mode (Disable)
*9** Welcome Mode (Enable)
**A0 4x2, 4x4 Indicator, Productivity Screen (Disable)(Dually)
**C* Temperature, Productivity Screen (Disabled) / Trailer Brake Controller (Enable)
**E* Temperature, Productivity Screen (Enabled) / Trailer Brake Controller (Enable)
***B Remote Start Menu (Enabled)
***1 Remote Start Menu (Disabled)
***9 Remote start menu (Disabled)
87B0 **** 26 Gallon Fuel Tank
8846 **** 28 Gallon Fuel Tank
8A58 **** 35 Gallon Fuel Tank
8B16 **** 37.5 Gallon Fuel Tank
8BD4 **** 40 Gallon Fuel Tank
8EC8 **** 50 Gallon Fuel Tank
9338 **** 65 Gallon Fuel Tank
BD** 40 Gallon Rear Fuel Tank
EC** 50 Gallon Rear Fuel Tank
Old Jan 24, 2019 | 10:46 PM
SkiLef's Avatar
SkiLef
720-01-02 B9CB
I will show them what you said tomorrow and hopefully they understand it. It doesn't make sense to me but thats because I don't understand why this happened lol. Im sure to them itll make some sense and maybe they'll be able to do something about it. Any more info that could be helpful? I really appreciate it
Old Jan 25, 2019 | 05:17 AM
Just Strokin
No need to show them those values. It has no meaning to them. They have a screen that displays tank sizes and that is it. They select a tank size for front or rear (depending on your tank location) and "write" it to memory and then exit the changes.
They do NOT get down to the level of the data shown above when one uses FORScan.
Listing those values is useless unless someone is knowledgeable of FORScan and going to use FORScan to make the change.
Old Jan 25, 2019 | 06:43 AM
SkiLef's Avatar
SkiLef
Ahh okay. I don’t believe he was using forscan. Pretty sure he was using some kind of special Ford programming. He was able to adjust everything but just went in to adjust the tank size and that was it the first time. Then i had problems with other things so he tried to go in and adjust those to fix it. So not sure what it exactly was. Headed back to the dealer now to try and fix it once again. Have a feeling the dealership is truly going to be lost and not sure what to do. Only thing i could honestly think of is getting a new PCM and then getting their side figured out and then I will just load my tunes back on.
Old Jan 25, 2019 | 11:36 AM
Just Strokin
The dealer uses the Ford/Rotunda/Bosch VCM/VCM2 to access the truck via the OBDII. Ford software, IDS, is the used to present to the tech the screens necessary to update the parameters as required. A dealer should never use a personal laptop and FORScan.
Old Jan 25, 2019 | 07:47 PM
cangim's Avatar
cangim
by phone listed doubt you are near me but if in Utah county let me know, we can fix it with forscan
GeorgeS59
Jan 12, 2021 02:10 PM
WXboy
2009 - 2014 F150
32
Mar 10, 2017 10:33 PM
old_beast
May 23, 2016 06:00 AM
Brandon D
6.7L Power Stroke Diesel
Apr 24, 2015 11:53 AM
jweidert
EcoBoost (all engine sizes)
Apr 11, 2011 08:17 PM
