302 Swap
Old Jan 22, 2019 | 09:58 AM
josephgorman44's Avatar
josephgorman44
302 Swap
Can I swap a 302 from a 1991 grand marquis to a 1991 f 150 that has a 302?
Old Jan 22, 2019 | 11:20 AM
baddad457's Avatar
baddad457
Yea, but you'll loose about 25 HP. The Marquis motor will have E6 heads on it, the F series had E7 heads. The E7's made 25 more HP. On the plus side the Marquis motor will have a roller cam, but it's the "base" roller cam, smallest in lift and duration of the factory roller cams Ford used in production. You could swap the E7 heads onto the Marquis motor and pickup the HP rating, but you won't be able to use a bigger cam. The Marquis 5.0 will have pistons with no valve reliefs due to the fact that in the E6 heads, the valves are located higher inside the head than all other SBF heads were. Bolting E7 heads onto it moves the valves closer to those pistons, so you're limited on how much more aggressive you can get with a camshaft.
Old Jan 22, 2019 | 11:22 AM
josephgorman44
Would it be advised to swap the cams too?
Old Jan 22, 2019 | 11:25 AM
baddad457's Avatar
baddad457
Re read what I posted above, I added some to it.
baddad457's Avatar
baddad457
The F series motor you have now has a flat tappet cam in it. Or should be as they didn't go roller in the trucks till 92
Old Jan 22, 2019 | 11:28 AM
josephgorman44
I will run this info by our in house mechanic aka my dad. We are using this truck for snow plowing and getting it mobile again is very time sensitive. A straight swap would be the quickest and easiest fix but if it wont perform we will have to pursue other options.
Old Jan 22, 2019 | 03:05 PM
baddad457's Avatar
baddad457
It will have more torque in the bottom end than the engine you have now. Swap the cam in it for an HO grind and you'll have basically an 86 Mustang HO motor
Old Jan 23, 2019 | 08:31 AM
josephgorman44
Do they exhaust manifolds from the truck bolt to an e6 head?
Old Jan 23, 2019 | 10:32 AM
baddad457's Avatar
baddad457
Yes, they will
bradsbronco
1966 - 1977 Early Broncos
Oct 13, 2015 11:18 PM
tjdad62
Feb 9, 2011 01:36 PM
Bogart
Apr 15, 2005 07:40 PM
falconinpa
Jan 19, 2005 05:18 PM
luvinfords
Jul 12, 2004 10:30 PM
