6.2 V8 Gas Engine swap 2011-2017
I am looking at a 2011 F250, 6.2 V8 Engine. It needs a new engine. I also have access to a wrecked F250 with the same 6.2 V8 engine. Can I use both the Engine and Transmission from the 2017 to the 2011?
Thanks
Thanks
It appears its a six-speed TorqShift-G automatic. The engine appears to be the same, probably just need to use some of the 2011 pieces. I can still use the old transmission (over 100k), but I would really like to use this new model, since it only has about 14k miles. I thought about using the wire harness and see about getting a tune to update the computer. Since its all apart I may install some of those Stainless Works Exhaust Headers...
You can but should have BCM & PCM from the '17. Starting in '15 the PATS became much more difficult for the end user
The gas-charged version of the 2017 Super Duty with the stout 6.2L engine is packed with potential just waiting to be unlocked. Any one of our 6.2L tuner kits combined with a cold air intake will dramatically improve horsepower and torque to optimize pulling and hauling, while an exterior kit will have your F250 turning heads in no time. We also have a full selection of lift kits and leveling kits to help you clear a beefier, more capable wheel and tire setup.
I want to mount 44 inch tyres on 24 inch wheels
Hey I was wondering if you ever did the swap I'm trying to do a swap on a 2013 wreck to a 2017 ?
Compatability
bopperd
Modular V8 (4.6L, 5.4L)
Feb 20, 2016 06:49 PM
