Sponsored by: Real Truck
Engine Life
Old Dec 18, 2005 | 06:40 PM
estimator's Avatar
estimator
Engine Life
How Long Will A 5.4l Gas Engine Last?
Old Dec 18, 2005 | 07:19 PM
AGORA's Avatar
AGORA
depens on how hard your gonna try to destroy it.
Old Dec 18, 2005 | 07:55 PM
dkstuck's Avatar
dkstuck
Till it quits!!!! Just about like any engine!
Old Dec 18, 2005 | 07:58 PM
ford390gashog's Avatar
ford390gashog
depends on what you use it for. but 220k is reasonable
Old Dec 18, 2005 | 08:03 PM
99f350sd's Avatar
99f350sd
I've heard of many going over 200k...
Old Dec 19, 2005 | 08:42 AM
sednec's Avatar
sednec
I have 1999 f250 5.4L supercrew with 225k miles, still running, no oil leaks, I loose about quart of oil every 3k miles which is not bad, I only used Mobil one since I got it, I think it really helped out, only thing engine is tired, it really struggles to accelerate and mpg went down drastically, but it is still running.
Old Dec 19, 2005 | 05:12 PM
estimator's Avatar
estimator
I Was Hoping For At Least 400,000k With Proper Maintenance
Old Dec 19, 2005 | 05:27 PM
bigblack02's Avatar
bigblack02
Maybe With A Diesel!
Old Dec 19, 2005 | 06:06 PM
stetson 1's Avatar
stetson 1
Gasser 250 to 300 k hoping for the best!
Old Dec 19, 2005 | 06:08 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
My 5.4 had around 60'000 miles of the worst conditions you have ever seen...
I could see one going to 400k with proper maintenance, and odds and ends here and there...
Old Dec 19, 2005 | 06:13 PM
ford390gashog
400k i doubt it. besides who wants to be driving the same truck for 400k? the rest of the truck will rust out before then.
Old Dec 19, 2005 | 06:23 PM
AerostarTrailHiker's Avatar
AerostarTrailHiker
My 95 aerostar with the 4.0L engine had 195K when i finally had to trade it in. One of the heads were cracked. Otherwise, it still ran great. I towed a lot with it and made non-stop runs from Chicago to Fla.
I would be shocked if the engine could not do a least 250K with good care, especially by changing the oil regularly.
Old Dec 19, 2005 | 07:02 PM
tjbeggs's Avatar
tjbeggs
better check out a powerstroke if you want that kind of mileage out of it! recent had a 5.4 superduty come into my shop with severe oil consuption with 100,000 on. it burned about a quart per 1000 miles or a bit less. didn't smoke but it had no leaks and the plugs had some nasty deposits on it! i own a 95 powertroke with nearly 190,000 on it and intend on getting 300 out of it. truck needs body work already and i am sure sometime before i hit my mark it will need a trans. but i love my truck and i am a mechanic so no repairs are out of reach.
but don't expect that kind of mileage out of a 5.4 it could happen but it is not the norm.
Old Dec 20, 2005 | 12:58 AM
NoMo's Avatar
NoMo
There's a post currently in the Expedition forum from a guy who has over 308,000 miles on his truck.
Old Dec 20, 2005 | 04:00 AM
slc10844's Avatar
slc10844
Proper maintenance is the key. With that they will last a long, long time.
