Vent Window Seals
Old Jan 17, 2019 | 12:14 PM
Suffolkman's Avatar
Suffolkman
Vent Window Seals
I have used the search function, but never seem to have much success with it. A simple one this time...to change the curved vent window seals on my 1950 F1, do I have to remove the whole fitting from the door. If so, is it pretty straight forward ?.
Suffolkman
Old Jan 18, 2019 | 09:49 AM
rusty48's Avatar
rusty48
Suffolkman
in a nutshell, yes, 2 oe\r 3 screws hold the vent window frame to the door and then you have to loosen/ the division bar so the vent window can move back a bit for removal Then the window needs to be removed from the frame to set the new seal and reverse the procedure.
Old Jan 18, 2019 | 12:54 PM
Suffolkman's Avatar
Suffolkman
Hi Kevin, Thanks for that...I will wait till it warms up a bit over here before I tackle it. Seeing as it look like you are rebuilding your truck ?...another cheeky question. My opening cowl is very drafty. On inspecting the cowl, I notice there is no seal on the fixed part (the hole in the part behind the hood). I am thinking their should be a rubber seal around the edge ?.
Suffolkmaan
Old Jan 18, 2019 | 01:14 PM
rusty48's Avatar
rusty48
Yes, I tore it down and on its way back together. Look down on todays thread page, see cowl gasket, they have pictures of cowl vent gasket and the fun it is to get installed. Have not tackled this one yet but soon to get some hands on with this one. Still playing with door/window seal and fuzzies install this weekend.
Old Jan 18, 2019 | 03:54 PM
Suffolkman's Avatar
Suffolkman
OK Kevin,,,,I will look this one up. Good luck to you with the truck rebuild. Thanks for your help.
Suffolkman
keisha9
Feb 12, 2011 05:59 PM
scottddove
Nov 17, 2008 11:52 AM
Bruce361
Nov 28, 2006 12:48 AM
svgearhead
Jun 15, 2004 08:44 AM
beartracks
15
Aug 11, 2002 10:05 PM
