1956 vent window seal
Old Feb 9, 2011 | 11:27 PM
keisha9's Avatar
keisha9
1956 f100..has anyone replaced the rear of vent window seal? i just received new ones with metal backing and rivots..Just seing if anyone has done this, I dont see how the rivots that were sent work. i've heard of gluing in? any ideas? thanks
Old Feb 10, 2011 | 03:08 PM
jaye's Avatar
jaye
If you are referring to the solid brass ones I did the ones on my 55 about 18 years ago, I just recently switched them out. I took the division bars off and used a round punch with a anvil or solid piece of mental on the back side. There may be an easier way yo do them or use pop rivets.
Old Feb 10, 2011 | 04:54 PM
dalmeida's Avatar
dalmeida
I'm not sure what you mean by the rear of the vent window seal. There are 5 rivets I had to place when I went from a one piece window back to a two piece. There were two for the lower pivot and three for the vent handle. I used a punch and a vise to secure the vent while I was pounding the rivets.
Old Feb 10, 2011 | 05:08 PM
dalmeida's Avatar
dalmeida
I'm thinking you must mean the little cups that appear to look like rivets. Those are actually inserts to protect the rubber seal from the screws used to attach the inner frame to the door. I believe those are only used in 53-55 vent windows not in the 56. They're probably included with the kit but not necessary.
Old Feb 10, 2011 | 07:00 PM
jaye's Avatar
jaye
I think he's talking about the seal that is riveted to the division bar; if you buy a new division bar the seal is already riveted in place. MF liste them on page 76 as glue in (1956) and steel reinforced which is what I had.
Old Feb 10, 2011 | 07:14 PM
keisha9's Avatar
keisha9
i think u are right...i just ordered the rubber reinforced because i have the div bar...did yours come with the mounts installed - where it mounts to the door and the back of vent window rubber??? i should just buy that . do u have a picture???
Old Feb 11, 2011 | 07:29 AM
jaye's Avatar
jaye
When purchase those years ago it was metal with the rubber over it with 2-3 holes in it to attach them to the division bar; the division bars I purchase a few months ago had the vent seal already installed. I only can get you a picture of the ones that came installed on my division bars. Let me know it that will help.
Old Feb 12, 2011 | 05:59 PM
jaye's Avatar
jaye
I took pictures of my old division bar where I installed the vent rubber however, when I upload all I get is an "X". I used pop rivets to install them.
dirtyoffroad
May 9, 2023 09:20 PM
FSTBLL42
6.4L Power Stroke Diesel
Feb 21, 2011 01:06 PM
bigacre
Aug 26, 2009 01:35 PM
SportCustomWalt
Aug 23, 2006 12:10 PM
wjawill
1978 - 1996 Big Bronco
Feb 22, 2005 11:01 AM
