Having a problem installing vent window rubbers
Old Nov 27, 2006 | 10:19 PM
Bruce361's Avatar
Bruce361
Is there a trick to install vent window rubbers? it seems the rubber around the vent window is to big, do u install the rubber around the frame first or the window thanx bruce361.
Old Nov 28, 2006 | 12:48 AM
Fuzydog's Avatar
Fuzydog
I did this on my 83 and regretted it due the new rubber has never sat flush with the body like the old one. I installed the new seal about a year ago. I recommend just getting a vent window from a salvage yard if your seal is bad. Otherwise, just wash the one you have. I am removing the new seal I installed and going with a used one off my parts truck after I clean it up.
