DEF meter
Old Jan 3, 2019 | 10:20 AM
Sonny Crockett's Avatar
Sonny Crockett
Bushpilot, Did you use Forscan to show the actual temp for coolant and trans above each gauge?
Old Jan 3, 2019 | 10:38 AM
bushpilot's Avatar
bushpilot
thats correct - I enabled the numbers over the gauges via FORScan
Old Jan 3, 2019 | 06:26 PM
edjunior's Avatar
edjunior
Wow, boy, that digital dash would sure be nice. Don't have it in mine. Wow.
Old Feb 19, 2022 | 02:15 PM
harleyjoeky's Avatar
harleyjoeky
Well this might be a good thread to ask this question. I use FORScan Lite to monitor my 6.7. A lot of info including Exhaust filter load. On my truck (2022 f-350 Powerstroke) the instrument cluster reads much higher than my forscan app. ie. instrument cluster 35% full. Forscan OBDII app 16%. Now I'm wondering which I should pay attention to. I turn off my Auto Gen so as to let it go past the 500 mile mark and turn it back on when it gets close to 100%.
Which do you all think is more accurate?
Old Feb 19, 2022 | 02:42 PM
4wd6.7L's Avatar
4wd6.7L
Edit- I see that you had already found the other thread.
Old Feb 19, 2022 | 04:57 PM
chadstickpoindexter's Avatar
chadstickpoindexter
Originally Posted by Hoss416
No reason to get an aftermarket monitor. If you do not have the DPF filter gauge in your dash, use FORSCAN to add it. You can monitor filter saturation and as it hits 99% you can monitor your regens. Also, the only regens are acitve, this whole passive thing is made up on forums. The so called passive regens are nothing more than high EGT's while pushing the engine to work under heavy loads.
From the manual… not “made up on forums.”
1L243
Dec 9, 2011 06:05 PM
mblanken881
Nov 15, 2010 04:52 PM
heathrunkles
20
Jul 31, 2008 06:06 PM
F350SD
Jan 3, 2007 10:04 PM
mstepchinski
Dec 2, 2004 11:03 PM
