Vibration when accelerating
Old Dec 24, 2018 | 10:38 PM
Brannon Sanford's Avatar
Brannon Sanford
Got a 95 f150 5.8l I'm having vibration in the front but it happens when I accelerate it will shake real bad and as I get faster it the shaking calms down but still had a steady shake I was told it could be my tires from the truck sitting for a few years and the tires may have developed flat spots and I was also told could be my torque converter going bad I mean it does seem like it's not shifting on time but when it does shift that's when my bad shaking starts any ideas?
Old Dec 24, 2018 | 11:36 PM
Ddaybc's Avatar
Ddaybc
If your tires are radial tires then they don't really develop flat spots. The old bias ply tires did that, radials, not so much. It could be something as simple as tire balance. However they generally get worse the higher the speed. I would look at your steering components. Tie rods, ball joints etc.
Old Dec 25, 2018 | 04:54 AM
tjc transport's Avatar
tjc transport
i ain't rite
"a bad vibration from the front" that goes away the faster you get could be anything from a bad sparkplug in the engine to a bad universal in the driveshaft.
Old Dec 25, 2018 | 08:00 AM
Brannon Sanford
I just changed all spark plugs wires and distributer cap with rotar and checked drive shaft everything is fine but Ive been told could be torque converter also from watching a video with someone having the same problem as me
Old Dec 26, 2018 | 04:04 PM
1995-F150-302-XLT's Avatar
1995-F150-302-XLT
Try driving the truck with OD turned off...and see if there is any difference.
While maintaining speed, try tapping the brake just enough to turn the rear brake light on. Again, is there any difference?
Old Dec 26, 2018 | 04:26 PM
1995-F150-302-XLT
I should say my previous post was from 1-6-2005 from another member. I just wanted to list it again as a possible tip.
Also, I added LubeGard 62005 and this had in the past made a 70% improvement in my automatic transmission. Sadly, the truck started having the same bad symptoms about 4 years later, I added another bottle, and it did NOT seem to make much of a difference the second time using it. But the LubeGard definitely made a distinct difference (in a positive way) when I FIRST used it.
durbancic
Apr 5, 2009 10:45 AM
tucker68h
1983 - 2012 Ranger & B-Series
Jan 30, 2007 07:42 PM
wolfe1104
77
Nov 8, 2006 08:17 PM
Downriver Thunder
Oct 3, 2006 09:18 PM
wolfe1104
Aug 24, 2006 09:08 PM
