Lost Overdrive 1992 F150 - Ford Truck Enthusiasts Forums
Old 12-13-2018, 03:42 AM
C Warren Const
C Warren Const is offline
C Warren Const is starting off with a positive reputation.
While on the highway today I put my foot in to get around somebody there was a big clunk that Jarred the truck real hard when I got off the highway about 30 miles later and pulled up to the stop sign the truck would not go it's like I didn't have a transmission, I put it down in first I had first gear and I had second gear, when I push my overdrive button I had all gears except the overdrive, it won't go with the overdrive button on, but does go with the overdrive button off. Has anybody had this problem... the truck has a hundred and eighty thousand miles on it I've never had an issue with this truck leaving me on the side of the road or breaking down and up till today that transmission is been fantastic. What do y'all think
Old 12-13-2018, 09:05 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Mark Kovalsky is offline
Mark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputationMark Kovalsky has a superb reputation
I think if I knew more about your truck I could give an intelligent answer. If you know which transmission it has, that would be a big help. If not which engine it has will also help.
With what you've given us all I can tell you is it done broke. That's the less intelligent answer,
Old 12-13-2018, 09:59 AM
C Warren Const
it is a 92 F150 with a 5.0 motor I believe the transmission is a e4od but I will check on the tag at the door and see if it tells me anything on it and get back with you, and thank you so much for getting back to me
Old 12-13-2018, 10:06 AM
timbersteel's Avatar
timbersteel
timbersteel is offline
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
Op stated he has On/Off button for overdrive.
Sounds like E4OD trans.
Old 12-13-2018, 10:39 AM
C Warren Const
Yes I climbed under it is an e4od, I looked under the hood everything seems to still be attached on the throttle body I didn't really notice any slipping when the overdrive was off and it was in 3rd gear
Old 12-13-2018, 10:44 AM
C Warren Const
In addition to fluid levels good and the fluid doesn't seem to be burnt it smells fine little darker than you know new fluid when you put it in but I think that's fairly normal especially on the truck with 180,000 miles on it
Old 12-13-2018, 10:54 AM
C Warren Const
In addition to fluid levels good and the fluid doesn't seem to be burnt it smells fine little darker than you know new fluid when you put it in but I think that's fairly normal especially on the truck with 180,000 miles on it, it doesn't slip in first or second and I didn't notice any slippage in third last night when I drove it home, it just won't go forward from a standing start in overdrive, I can tell you that jolted gave me on the downshift when I went to pass I thought I left some parts on the pavement it was that bad
Old 12-13-2018, 11:10 PM
Mark Kovalsky
I suspect the overdrive one way clutch has failed. That clutch has to hold in first gear. With the OD turned off, or the shift handle in 1 the coast clutch is applied and holds the torque that the one way clutch isn't holding. This takes a rebuild to fix.
Old 12-26-2018, 03:14 PM
C Warren Const
thank you very much that makes sense, because with the overdrive switch in the off position it goes fine I drove it about six hundred miles after that at with no problems but I have decided that I need to rebuild that transmission or replace it I found one with 60,000 miles from LKQ $750 with the one year guarantee parts and labor I thought that was a pretty decent price but for right now I might just go ahead and tear that one down and try and rebuild it myself just to see if I can do it see if it's a challenge I'm fairly certain that I can probably do it as long as I pay attention to what I'm doing and have a nice clean workspace , do you believe this is something that average guy who knows his way around a wrench can do? For now I'm driving my 96 Eddie Bauer single cab short bed with a straight 6 in a 5-speed probably never will own another automatic I guess even though that one went almost 200,000 thank you so much for your time and your input in this matter I appreciate it
Old 12-26-2018, 04:56 PM
sandymane's Avatar
sandymane
sandymane is offline
sandymane is gaining momentum as a positive member of FTE.sandymane is gaining momentum as a positive member of FTE.
Since the E4OD is electronically controlled, it might be wise to run diagnostic codes and see what comes up. Sandy
Old 12-26-2018, 06:46 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
FORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputationFORDF250HDXLT has a superb reputation
How To Reman The E4OD/4R100 - Complete Video Walkthrough
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
