Dual shock steering stabilizer
Old Dec 24, 2018 | 03:21 PM
catrasca's Avatar
catrasca
I just installed the RC N3 system after fitting a 2.5 leveling kit, 20” wheels and 35” tires. I did not relive the stock steering stabilizer. Should I?
The steering feels so much better than stock after the lift... It’s amazing. It is a little hard on parking maneuvers but there is no wobble on speed humps or pot holes.
Old Dec 24, 2018 | 03:27 PM
jwc410's Avatar
jwc410
I left mine on for a while then I removed it. I liked driving it better without the stock one
Old Dec 24, 2018 | 03:39 PM
catrasca's Avatar
catrasca
Thanks for your reply. I guess it’s an easy thing to try out.
Old Dec 25, 2018 | 11:44 AM
catrasca's Avatar
catrasca
I tried to remove the stock stabilizer shock but it’s stuck. Any tips to remove the end on the steering linkage? The end that bolts on to the frame is already out.
Old Dec 25, 2018 | 01:27 PM
jwc410's Avatar
jwc410
It is a tapered joint like a tie rod end. I used a small puller that I had. If you do not have a puller it can be difficult
Old Dec 25, 2018 | 02:24 PM
catrasca's Avatar
catrasca
Yup, that’s what it is. I’m surprised it’s seized on a brand new truck. I do not have a puller but I’ll give it a shot with a pickle fork tool and go look for a puller tomorrow. In the mean time I put the frame side back on.
Old Dec 25, 2018 | 03:04 PM
Truckie256's Avatar
Truckie256
I had to use a pickle fork on the last one
Old Dec 25, 2018 | 04:46 PM
catrasca's Avatar
catrasca
I’ll give it another try tomorrow and report back. Steering feels great with all 3 dampeners when driving but a little bit too stiff when maneuvering in tight spots at low speeds (parking).
Old Dec 26, 2018 | 12:06 PM
catrasca's Avatar
catrasca
Pickle fork from harbor freight ($7.99) did the job in 5 minutes. It’s amazing how the right tool for the job makes it so much easier.
I like the steering better without the stock dampener on. Still firm but now I don’t have to wrestle the steering wheel when maneuvering in parking lots.
Old Dec 26, 2018 | 04:19 PM
dave91gt's Avatar
dave91gt
Thanks for sharing. My truck has crazy bumpsteer and I'm going either Fox single or this route.
Old Dec 26, 2018 | 04:27 PM
catrasca's Avatar
catrasca
Keep in mind that if you don’t have a lift of at least 2” up front the dual system will not fit.
Old Dec 26, 2018 | 04:34 PM
jwc410's Avatar
jwc410
this is the same opinion I had.
Old Dec 27, 2018 | 02:29 PM
catrasca's Avatar
catrasca
We went skiing today and the roads to the place are really bad. I’m going to reinstall the stock steering shock after the bump steering I experienced today and give that a try.
Old Dec 27, 2018 | 02:52 PM
Tricon's Avatar
Tricon
The location of the stock steering damper is so much better suited to control those forces. A good single there is miles better than using a dual down on the axle.
PatsfanTN
Feb 20, 2019 04:09 PM
Jbranton
Nov 16, 2018 10:22 AM
DL222
Jul 3, 2017 12:10 AM
bigb56
Dec 22, 2012 10:10 PM
cbzdel
Feb 6, 2012 12:50 AM
