Sponsored by: Real Truck
2 or 3 steering stabilizers?
Old Feb 4, 2012 | 02:34 PM
cbzdel's Avatar
cbzdel
I have the rancho dual steering stabilizer and I can not get a straight answer on if I should remove the stock one out run with 3 of them in place. I emailed rancho with no , so I called them and they were closed so I left a message. Never heard back so I called again and got ahold of a tech, they told me to remove the stock stabilizer as it would be to much stress on the steering. Then I just got an email from them saying to leave it on. And last night I got a call from them retuning my phone call and the tech said leave the stock one on, I trills him about the other tech saying removing it, and he said it's really a personal prference.. What are you guys doing?
Old Feb 4, 2012 | 04:44 PM
tonefordays's Avatar
tonefordays
I've got a 6" procomp lift with dual front stabilizers, and I still have the original stock one in place. My steering has never been an issue. I just have to make sure the truck is rolling a little when I turn the wheels, or it feels a little tough to turn, but I think that's due to the bigger/wider tires, and not the stabilizers.
Old Feb 4, 2012 | 05:19 PM
dscabra's Avatar
dscabra
There is absolutely no need to run multiple stabilizers. If you are running the in-line Rancho, I'd remove the factory stabilizer. I can't speak with any experience, but I've been told that if you run more than one stabilizer setup at the same time that they can actually interfere with each other and not allow them to do the intended job.
Old Feb 4, 2012 | 06:45 PM
RAPR's Avatar
RAPR
I have the Rancho dual set up and didn't remove the factory stabilizer and it seems to be working fine and made a world of a difference in handling. The only thing is when I turn, the steering wheel doesn't straighten back out on its own anymore.
Old Feb 4, 2012 | 08:58 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I would remove the factory and run one or two of the same model stabilizer.
Old Feb 5, 2012 | 06:24 AM
critterf1's Avatar
critterf1
I'd remove the stock one.
Old Feb 6, 2012 | 12:50 AM
GregsSD's Avatar
GregsSD
If you add steering stabilizers that mount to the tie rod then there is really no reason to keep the stock one in place.
The tie rod mounted stabilizers do a much better job than the stock one, when I added my dual kit I left the Rancho one that I already had in the stock position on, but after awhile I removed it and found that the truck drove just as good and also was easier to turn.
MILAGRO33
Mar 27, 2019 04:59 PM
PatsfanTN
Feb 20, 2019 04:09 PM
lewis racing
Sep 11, 2014 10:43 PM
Robs06SuperDuty
Jun 12, 2009 11:44 AM
Benny2002
28
May 30, 2007 12:35 AM
