Oh God, another problem
Old Dec 23, 2018 | 06:21 PM
1981 F100's Avatar
1981 F100
Unhappy Oh God, another problem
Got a trans cooler line leak fixed, topped off fluid to correct level, then went thru the gears, they worked fine. Put in park, to double check fluid then went to run thru gears again. This time I had nothing, no forward gears or reverse. Shift linkage is correctly adjusted. Only thing about this replacement trans, is that the kickdown lever would just spin around freely, not sure if that would be causing my problem
Old Dec 23, 2018 | 08:08 PM
NotEnoughTrucks2014's Avatar
NotEnoughTrucks2014
You speak of a replacement transmission. What's the back story on this?
Old Dec 23, 2018 | 08:11 PM
1981 F100's Avatar
1981 F100
Was a working transmission my friend (who let me have the truck) had stored in his garage
Old Dec 24, 2018 | 01:58 PM
NotEnoughTrucks2014
It would seem obvious that it is no longer a working transmission. All too often, that transmission that worked fine when pulled X amount of years ago does not work when reinstalled. Guessing what may be the cause is risky at best.
How about the whole story, both on the replacement transmission as well as what was wrong with the one originally in your truck? Details such as engine type, transmission type, mileage, and any other pertinant detail will help.
Old Dec 24, 2018 | 03:08 PM
1981 F100's Avatar
1981 F100
300 , C4. Shows 94K on truck. The original C4 trans had second burnt out. Replacement one was working when pulled 8 years ago
Old Dec 24, 2018 | 05:29 PM
1981 F100's Avatar
1981 F100
I got to thinking while I was on the throne, I wonder if the main pressure valve in the lower valve body is sticking or stuck, since it is engaging one minute and not the next
Old Dec 24, 2018 | 09:32 PM
1981 F100's Avatar
1981 F100
My friend who gave me the truck, is going to get me another transmission so I don't have to mess with this one
Old Dec 26, 2018 | 07:54 AM
Odisvan's Avatar
Odisvan
does rpm go up and down when you go from in gear (drive or reverse) to neutral or park? what happens in gear with you throttling up and down a lot, doesn't try to move at all when revved? Sounds just low on fluid, did you check while fluid is super hot? That's when you should, not cold, not warm, full up operating temp.
Old Dec 26, 2018 | 05:38 PM
1981 F100's Avatar
1981 F100
Fluid was hot, would go in gear once,moved it a couple feet each way, then after re checking level, it had nothing.RPM did not change. Fluid level was correct
Not messing with this trans, (It had sat 10 years)
picking up a known good one this weekend and start over
Misn 1
Oct 21, 2013 05:00 PM
c0lumbia
May 25, 2013 12:48 PM
merccougar93
Aug 20, 2010 10:42 AM
laneyboy6933
Feb 24, 2008 10:46 PM
JTHill24
Aerostar
Mar 12, 2005 04:27 PM
