IDM ?
Old Dec 18, 2018 | 10:11 PM
nomad221's Avatar
nomad221
IDM ?
Hey guys. Hoping your holidays are good and Merry Christmas !
I'm experiencing a problem with my truck. After a cold start up, the problem I'm having is when driving down the road I am experiencing a sort of power loss at normal speed limit speeds. Kind of like a light loping or missing feeling from the engine. The other day, I drove a slight incline before a turn and the engine went to no power for a second and I heard what I think was all of the injectors buzzing at once. It was weird.
I think I have another IDM on it's way out. Checked codes this afternoon and no dice. I did not check the CPM harness but, will tomorrow. The symptoms I had from the last CPM failure was engine shutoff on downgrades or at times, on deceleration and when it finally failed, the engine died, cranked, no start and white smoke. Nothing like what is going on now.
Any ideas ?
Thanks!
Old Dec 19, 2018 | 05:59 AM
427 fordman's Avatar
427 fordman
Are you sure it's not the exhaust back pressure valve closing which would be normal when cold? It will make a loud hissing type sound with lack of power
Old Dec 19, 2018 | 08:07 AM
nomad221's Avatar
nomad221
Removed it when I installed a new turbo.
Old Dec 19, 2018 | 08:46 AM
SchaefferUSMC's Avatar
SchaefferUSMC
Did you check your cps? My 94.5 would have like a split second where it would die every now and then, new cps fixed it, I didnt hear any buzzing though
Old Dec 19, 2018 | 12:19 PM
Hussler's Avatar
Hussler
I agree, sounds like the EBPV closing.
What did you remove / install, maybe a new pedestal and EBPV valve delete kit? Your description sounds perfect for the valve still closing when cold, normal.
Old Dec 19, 2018 | 08:03 PM
nomad221's Avatar
nomad221
Installed the pedestal and EBPV valve delete kit with the turbo. It stumbled again today under 3/4 load. No buzzing though. Starting to think it is the HPOP. Fresh oil change 300 miles ago and full with the dipstick. Just wish it would throw a code. I'm going to swap the CPS asap.
Old Dec 19, 2018 | 08:09 PM
MagnumPD's Avatar
MagnumPD
Fuel pressure?
Old Dec 19, 2018 | 08:41 PM
AK gman's Avatar
AK gman
hows the fuel filter & little screen in side of fuel bowl. Maybe read some live data on the HPOP and IPR with the Torque app, Forscan or similar and see if your numbers are right.
Old Dec 19, 2018 | 10:18 PM
nomad221's Avatar
nomad221
Fuel pressure at 60 PSI. Please tell me about these new apps. Android ?
Old Dec 20, 2018 | 12:09 AM
AK gman's Avatar
AK gman
Theres lot of info on this site to get you going with the Torque pro app for cell phones. Or you could try the free program Forscan for windows thats Ford specific for a laptop. Forscan is a free download. Other more expensive apps out there like auto enginuity* that do much more. Torque lets you monitor several sensors on our obs trucks. Do a search and you will find what you need on this site. I put Torque pro on a cheap amazon tablet and it works good. The readings you get from Torque will go a long way in diagnosing your truck issues.
Dieselgrowl
Oct 11, 2013 12:37 PM
MiamiPSD
Oct 24, 2012 10:18 PM
DblD353
Oct 22, 2011 12:49 AM
wyocat24
May 3, 2011 08:49 AM
blue46gt00
May 19, 2006 08:05 PM
