Weird problem with 96PSD
Old Mar 28, 2006 | 09:28 PM
blue46gt00's Avatar
blue46gt00
Question Weird problem with 96PSD
After searching I'm wondering if my problem is the CPS. It doesn't do it all the time and seems to only do it after I stop or idel for a while. When I accelerate it sputters and I can feel the power loss. After getting on it it seems to go away and won't do it again for a while. What do you all think? CPS?? Or maybe the ICP sensor. Thanks.
Old Mar 29, 2006 | 11:10 PM
soutthpaw's Avatar
soutthpaw
any trouble codes from the computer???
Old Mar 30, 2006 | 10:11 AM
blue46gt00's Avatar
blue46gt00
I'm not getting a check engine light or anything. I don't have anyway to check for codes? Any Ideas?
Old Mar 30, 2006 | 10:38 AM
legacy76's Avatar
legacy76
I have a '96 PSD and mine does the same thing. It only does it when I accelerate. I can't figure out what the problem is. The engine just bogs down and I can feel the power loss, then it recovers after a couple seconds and takes off.
Old Mar 30, 2006 | 11:45 AM
1997F-350's Avatar
1997F-350
ipr???????loose nut??
Old Mar 30, 2006 | 03:39 PM
blue46gt00's Avatar
blue46gt00
What is the IPR? And Loose nut?? Please explain. Thanks
Old May 17, 2006 | 05:09 PM
jcarr922's Avatar
jcarr922
Mine is doing the same thing whaT DID you figure out? thanks
Old May 17, 2006 | 07:04 PM
Cuda_jim's Avatar
Cuda_jim
TPS Maybe?
Old May 17, 2006 | 07:13 PM
1997F-350's Avatar
1997F-350
the ipr is on the back of the hpop. its down right in front of the fpr manifold. check the wiring and the tin nut that holds the solenoid on.
Old May 17, 2006 | 09:22 PM
powerstroked162's Avatar
powerstroked162
the ipr is the injection pressure regulator. it has somethin to do with the injectors. it either regulates fuel pressure or oil pressure to the injectors. not really sure. give me a hand F350
Old May 18, 2006 | 08:20 AM
plowhand's Avatar
plowhand
Playing in the Dirt
IPR regulates the oil pressure to the injectors. Also check the following: fuel pressure at the schrader? (spl) valve on the Fuel Pressure Regulator, it should be 40-60 psi. If it is low it could be: stuck FPR valve seat, worn out fuel pump, clogged pickup screen in the tank, gunk in the bottom of the fuel filter housing, clogged FPR screen. Is your fuel filter clean? Does it bog down when you accelerate while parked or only while driving?
Old May 18, 2006 | 11:37 AM
Ron McCafferty's Avatar
Ron McCafferty
Do you have Auto Zone near you? If you do they may check your codes if any. They do in Lynchburg, VA, anyway. But after you check the IPR and check your fuel pressure, if you have the tools, i.e. pressure gauge, and if you are still having that same problem. Have your system checked for codes. I have seen the CPS, cam position sensor, cause a hesitation from a idle and cause a lag when you punch the pedal and not turn the light on. Most times it will cause a check engine light but with OBDII if it does not occur long enough or enough times it will not set the lamp on but it will store the code. You may not have noticed the lamp if it came on momentarily and went out. You can buy an OBDII code checker from most auto parts places from about $20-200 depending on what info you would like.
Old May 19, 2006 | 08:05 PM
psu927's Avatar
psu927
dude that's your EBPV (exhaust backpressure valve). closes at certain temp. to help truck warm up. But it does it every time I start my truck from cold. Most guys remove or unhook them.
cabloom300
Jan 11, 2014 10:43 PM
Fordbronco69
Jul 27, 2013 10:48 AM
Rpayne
Oct 7, 2012 08:42 PM
stangman516
20
Nov 13, 2008 02:26 PM
hott-rodd
22
Dec 12, 2005 02:49 PM
